passenger side airbag
Old Mar 10, 2007 | 07:02 AM
71shovelhead's Avatar
71shovelhead
Does anyone know a simple way to disable the passenger side airbag on a 2006 E 150? ( mine doesn't have the ooptoinal switch)
Old Mar 12, 2007 | 09:43 AM
mrfixit64857's Avatar
mrfixit64857
hmmm... not sure on this. might have a seperate fuse; if not, you're probably going to need to disconnect the batteries, wait 15 min to let everything power down, then remove the airbag and disconnect the terminals and tape them off or wire in your own switch.
Old Mar 12, 2007 | 07:14 PM
71shovelhead
do you know if its a relay controled circuit?
Old Mar 12, 2007 | 08:27 PM
mrfixit64857
No. there's no room for the time delay of a relay. they need to deploy instantaneously and every second counts!
Old Mar 12, 2007 | 08:28 PM
Desert-Rat's Avatar
Desert-Rat
Cool
why you removing it? I thought about removing mine so I could set a small lap top in there and use my map software on trips, but I was told that if there was an accident I am liable for its removal if my passenger is hurt??????
Old Mar 12, 2007 | 09:21 PM
mrfixit64857
I think He's just wanting to disable it, maybe for a child seat?
Old Mar 12, 2007 | 10:15 PM
maples01's Avatar
maples01
I'd like my drivers side air bag disabled, I'm a para-plegic, I fear that air bag causing more hurt than good.
Old Mar 14, 2007 | 09:15 PM
71shovelhead
You are correct about the child seat, and I don't want to remove it, just disable it
Old Jul 26, 2008 | 10:32 PM
lrhall's Avatar
lrhall
I have a 02 E-250 that I need to disengage the passanger airbag for a child's seat. Did you find out anything more on this?
Thanks,
Lionel
Old Jul 26, 2008 | 11:14 PM
Desert-Rat's Avatar
Desert-Rat
the dealership offers a disable switch...
Old Jul 27, 2008 | 03:03 PM
rclarke's Avatar
rclarke
There is no easy way. Even if Ford makes a shutoff kit for your E150, which I doubt, you will have to get written permission from the federal government before your Ford dealer can install it.
Old Jul 30, 2008 | 11:12 AM
wolfmanagh's Avatar
wolfmanagh
I don't think there is any law that requires it to be there since I see vans all the time that don't have an airbag on that side at all. My 98 didn't have one. I thought about doing a tray there for a laptop but instead I purchased the correct panel and the electronic box and airbag and put it in. I do remember reading here somewhere where someone put the kill switch from the dealer into a truck but I can't remember how long ago that was. I believe the dealers give the switch away if requested just like seatbelt extenders which the also don't charge for.
Old Jul 30, 2008 | 02:17 PM
maples01's Avatar
maples01
Go ahead, it isn't the government you have to worry about, it's your insurance company, in an accident if your vehicle is said to have 2 airbags and one does not deploy due to being tampered with, they can refuse to pay the claim.
brc777
1983 - 2012 Ranger & B-Series
Jan 6, 2017 02:38 AM
DBANDGB
2009 - 2014 F150
Feb 29, 2016 10:18 PM
j1boomer
Jul 26, 2015 05:58 PM
Shark Bait
Feb 25, 2010 07:29 PM
bdee
Nov 24, 2004 07:21 PM
