Rear-end squeak
Old Mar 9, 2007 | 11:52 AM
bryan_1980's Avatar
bryan_1980
Angry Rear-end squeak
Sorry if this is a redundant question, but I searched all through the forum and didn't see where someone else answered this question. I have a '99 Explorer with 95,000 miles on it. Lately, I've noticed that the rear-end squeaks pretty loud particularly when going over a speed bump, but I can also hear it when I'm driving down a bumpy road. My question is could this be from worn shocks, or maybe worn bushings of some sort? As far as shocks go, the truck doesn't seem to wallow or have excessive float. I just bought this truck from my parents, so I probably should ask them if they ever replaced the shocks.
I'd like to get this problem taken care of, it's driving me nuts!
Old Mar 10, 2007 | 12:42 AM
kevin74656's Avatar
kevin74656
Originally Posted by bryan_1980
...My question is could this be from worn shocks, or maybe worn bushings of some sort?
Yes, any of those things can cause the squeak you describe. If the shocks are original, it's past time to replace them whether or not they're causing the noise.
If you bounce the rear of the truck (when stopped, of course! ), do you hear the noise? If you do, spray some WD-40 on the shock rods. If the noise stops, you've found the problem. If not, spray one bushing at a time until (hopefully) the noise goes away. The last thing you sprayed is the culprit.
Good luck!
Old Mar 10, 2007 | 05:01 PM
bryan_1980's Avatar
bryan_1980
Yes, it does make the noise when I bounce it, so I guess I'll whip out the WD-40 and find the offender. That'll do until I get around to replacing the shocks. Thanks for the help!
Old Mar 10, 2007 | 05:12 PM
kevin74656's Avatar
kevin74656
You're very welcome. Let us know what it turns out to be!
reggiedunlop
1983 - 2012 Ranger & B-Series
May 28, 2017 11:48 PM
Mattman81
Jan 17, 2017 12:38 AM
berrset
Jun 23, 2016 07:31 AM
ZachManXLT
1997 - 2003 F150
Feb 2, 2016 05:24 PM
Bonkrr
1997 - 2003 F150
Sep 14, 2009 10:19 PM
