I saw one on ebay NIB last year went for $27, first new one i've ever seen available.
I have worn the rod ends down until they broke off just do to high mileage wear even when lubed.
Crane's assembly lube is one thick sticky lubricant that works great on these throttle linkages.
ya, i tried searching in google the part number Bill gave me, i got pretty much the same results, it was all ebay, and all the auctions had already ended.
The problem with the brackets at the wrecking yard were: first of all, i come from a fairly small town, so selection was slim, and second, the ones i did find were already weak.
ya, the first place i checked was LMC, then i spent a good week or 2 just searching on google, finding every possible business that sold '67 F-100 parts, but i kept getting the same results, nobody has throttle linkages.
