Ignition Switch
Old Mar 9, 2007 | 03:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
2 screws behind the wheel to take the pad off. once you have the pad off, you will need a steering wheel puller.
this sounds like one of those days where you need to call a friend that knows auto mechanics, and owes you a favor.
Old Mar 10, 2007 | 09:23 AM
rkymtnman30's Avatar
rkymtnman30
there are a couple of screws on the back side of the steering wheel that hold the the front cover on remove the cover and you should see how it comes apart, I do believe you will need a puller to seperate it after you take the nut off though. Fairly straight foward though. Just a thought though you make want to inspect the ignition switch and connecting rods before you tear the column all apart, I would take the two bolts the hold the column drop it down and see if it is binding up or anything.
Old Mar 10, 2007 | 04:00 PM
hosemandc's Avatar
hosemandc
Thanks for all the advice. I am being deployed on monday to get rid of a coast guard ship so i am going to put this project on hold till April. I was hoping for a simple solution. I did find a steering wheel puller at our auto hobbie shop on base so I am just going to pull it all apart and give it all a once over. I will repost when I get back with results. Thanks again to all that chimed in.
Old Mar 25, 2007 | 09:50 AM
cowboy51's Avatar
cowboy51
I used a balance wheel puller. You should be able to borrow one from AutoZone. Pay a rental fee and get it refunded when you return it.
tinman52
Nov 15, 2013 10:50 PM
aerodam
Aerostar
Feb 21, 2006 09:48 PM
Wakeboarder141
1978 - 1996 Big Bronco
15
Aug 4, 2004 09:48 AM
mep123
Oct 23, 2003 10:50 AM
sigtauenus
Mar 15, 2002 10:45 AM
