Driveshaft problem
Old Mar 8, 2007 | 11:26 AM
tonydlt's Avatar
tonydlt
Driveshaft problem
hey i have a 70 ford f100 shortbed automatic, im having problems finding the center yoke for my truck. i have a 2 piece driveshaft i need the yoke in the center where both connect. does anyone know where i could find it. Thanks
Old Mar 8, 2007 | 11:49 AM
wizzard351's Avatar
wizzard351
save your self a bunch of headaches and have a 1piece shaft built.unless your going for 100% origanal a 2 piece shaft is not needed on any 2door long or short bed
Old Mar 8, 2007 | 05:22 PM
BobbyFord's Avatar
BobbyFord
Any driveshaft shop should have everything necessary to build any driveshaft.
Where I live we have a shop that I've been dealing with for years that will make shafts from steel, aluminum, carbon fiber, etc.
Old Mar 8, 2007 | 08:13 PM
FordBoypete's Avatar
FordBoypete
Why on earth are you using a 2 pc shaft On A SWB Truck?
I agree with Bobby you can get whatever you want Fabbed at any decent Shaft shop, BUT, With a SWB truck a single shaft set up is the sensible way to go. IMHO atleast
FBp
Old Mar 11, 2007 | 12:14 AM
Yogi-96blazer's Avatar
Yogi-96blazer
um I have a long bed and it has two i nocticed the otherday where the 2 go together at that the rubber or whatever looks cracked and all, i was wondering if I could replace that or needed a new mount or what.
Old Mar 11, 2007 | 05:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This part is known as the Driveshaft Center Support. They are available from parts houses and Ford dealers. The d/s center support used on 1969 F100's were used on other models for many yrs and will be easy to find. The entire support is usually sold as an assembly because, in addition to the rubber and metal supports you see, there's a bearing and baffles there also.
D9TZ-4800-A .. Driveshaft Center Support
Old Mar 11, 2007 | 09:39 AM
Yogi-96blazer
Oh thanks for the info
jswford
1983 - 2012 Ranger & B-Series
May 24, 2015 10:21 AM
onadraw
May 16, 2015 03:19 PM
Alex Bindas
Mar 16, 2014 04:23 PM
