driveshaft phasing
Old May 23, 2015 | 05:16 PM
jswford's Avatar
jswford
driveshaft phasing
can anyone draw me, or take a picture of how the 2 piece driveshaft phasing should be? I replaced my carrier (center) bearing on my 93 4x4 ranger today. did i mark them? no, should i have? yes. ok, i lined up the yokes on the front shaft to match took it for a spin and it has vibrations. i look at the yoke going into the trans, and the yoke going into the rear end, and they are not exactly lined up. the only thing i could to to make these line up is to move the short driveshaft yoke so they do not line up. which in my mind, if this is causing the problem, wouldnt that be the same? i've seen where you want all of the yokes to line up, but they just cant. so i need some good pics or a good drawing or something.
Old May 24, 2015 | 10:09 AM
jswford's Avatar
jswford
i read that the 2 piece driveshafts are balanced as a total assembly, so i rotated the 2 pieces 180 and that solved the problem.
Old May 24, 2015 | 10:21 AM
onadraw's Avatar
onadraw
quentinc25
Jan 6, 2016 01:10 PM
onadraw
May 16, 2015 02:40 PM
someday
Jun 17, 2007 09:29 AM
harmdogg1978
Sep 27, 2004 10:25 AM
masterbeavis
Sep 13, 2002 09:46 PM
