leaf springs
Old Mar 6, 2007 | 03:27 PM
ford hunter's Avatar
ford hunter
leaf springs
my 78 1/2 ton has 2 leaves left on the passenger side and 3 on driver side that are not broke. can i put 3/4 springs under with little to no modification? what would be the benefits of putting leaf under the front?
Old Mar 6, 2007 | 04:43 PM
scottie2hottie's Avatar
scottie2hottie
for the rear springs as long as they are the same width it should be a bolt on, for the front the only benefit of a leaf front is sturdiness, they are much stiffer though.
Old Mar 6, 2007 | 09:30 PM
LOWBOY1979's Avatar
LOWBOY1979
getting new stock springs is not that expensive, any reason you want to go to 3/4 ton springs?
Old Mar 6, 2007 | 09:35 PM
Mikestrucks's Avatar
Mikestrucks
If you have 2WD, your 1/2 ton would probably have 2.5 inch wide rear springs. All the 2WD 3/4 rear springs I know of are 3 inches wide and won't fit in your 1/2 ton rear spring hangers! I have noticed that some 4wd 1/2 tons have the wider 3/4 ton springs so it will work if you have one of those. Also, don't be fooled while measuring things due to the spring hangers having an extra 1/2 inch over the spring width. (example, the 1/2 ton 2.5 inch spring will have a 3 inch hanger and a 3 inch wide spring will have a 3.5 inch wide hanger. Hope this helps out some. Mike.
Old Mar 7, 2007 | 06:01 AM
scottie2hottie
highboy rear springs are only 2.5" wide....
Old Mar 7, 2007 | 07:00 AM
buzzbait65's Avatar
buzzbait65
not to be picky, but the 4 highboys i have owned had 2 1/4" rear springs (69,72,74 and early 77)
Old Mar 7, 2007 | 07:47 AM
ford hunter
just to clarify my 78 is 4x4 and has 3" wide springs. i want to up to 3/4 ton springs because i haul wood and concrete every once in a while and want a little more steering control. would the 3/4 ton springs help in that aspect?
Old Mar 7, 2007 | 09:09 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Id just order new springs for your model of truck. When you order them tell them what you plan on doing with the truck and maybe add an extra leaf or add some overloads. That way nobody gets confused and you end up with a headache. As for leafs in the front...thats more work than its worth. You can get new coils that would be way better than the old worn ones.
1994F2507.3L
Dec 10, 2010 11:24 AM
spinella
Mar 3, 2010 08:49 PM
Brown Falcon
Nov 20, 2008 11:35 AM
fordinmudd
Offroad & 4x4
Jul 21, 2005 11:35 PM
mnm99
1978 - 1996 Big Bronco
May 4, 2003 12:26 AM
