Sponsored by: Auxito
abs light.....need help
Old Mar 6, 2007 | 11:58 AM
tj0911's Avatar
tj0911
Question abs light.....need help
1997 ford F250LD .Had it checked by a local shop. They told me it was the brake controller. The ABS do not work at all. Found out the hard way. I was given a oddly high price to have it fixed. How much are these controllers. Would a junk yard be worth a shot? Any help would be appreciated....Thanks, Todd
Old Mar 6, 2007 | 05:31 PM
ncranchero's Avatar
ncranchero
Personally I would try a used one for sure. Make sure you get one that has not been disconnected/removed for a while. If you went to buy a new one you'd think you were buying another truck!
1997
Anti-Lock Brake Parts
Ford Truck 150 A 2G5006 $150 W J Lee Used Cars and Parts Inc. USA-SC(Effingham) 800-922-9771
1997
Ford Truck 150 XLT,ATOD,4x4 T 6675 $150 Baker Truck Parts USA-SC(Greenville) 864-277-9479
1997
Ford Truck 250 A RJ2325 $Call Barnette's Auto Parts USA-SC(Sumter) 1-800-669-4095
Old Mar 6, 2007 | 09:08 PM
tj0911's Avatar
tj0911
thanks buddy.......
Old Mar 6, 2007 | 09:40 PM
tpgeneral's Avatar
tpgeneral
http://www.modulemaster.com/fordabsbsrepair.html
Try this!
Mine is on too, I'm still convinced that the cruise control fix did something to the abs system. If I start my truck with my foot on the break the light will cycle but then go out. As soon as I let up the light goes on.
Old Mar 7, 2007 | 06:18 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by tpgeneral
....I'm still convinced that the cruise control fix did something to the abs system. If I start my truck with my foot on the break the light will cycle but then go out. As soon as I let up the light goes on.
It's quite impossible that the cruise recall in any way affected the ABS system. Look elsewhere.
The ABS POST diagnostic does not finish until the brake pedal is released. You still have an ABS fault. Pull the ABS codes to see what it's complaining about.
Steve
Old Mar 7, 2007 | 10:22 AM
tpgeneral's Avatar
tpgeneral
Do you have a wiring diagram to substaciate your coment. The cruse wire that they replaced connects to a pressure switch on the brake master.
Old Mar 7, 2007 | 11:26 AM
projectSHO89
If you had a basic understanding of the purpose of the switch and the harness installed, you would know the answer to that comment.
This subject was covered in very great detail by myself and others in the period leading up to and including the issuance of the recall. You should be able to locate those posts with the assistance of the SEARCH feature. I'm not inclined to repeat myself.
Steve
Old Mar 7, 2007 | 11:44 AM
tpgeneral's Avatar
tpgeneral
I don't have a basic understanding of the purpose of the switch, I don't have access to diagrams. This is why I post to get help from people who do.
Old Mar 7, 2007 | 11:52 AM
projectSHO89
Review my posts regarding the cruise issue starting back in Nov or Dec of 04.
Old Mar 7, 2007 | 11:53 AM
tpgeneral's Avatar
tpgeneral
thank you steve
galaxie521
Bronco II
May 3, 2013 11:58 PM
Renegadex
Mar 27, 2006 11:42 PM
Todd525
Aug 3, 2005 09:59 PM
firstford
Sep 12, 2004 06:01 AM
Todd_M_S
Aug 27, 2003 10:49 PM
