brake light failure ford explorer
Old Mar 5, 2007 | 06:33 PM
MisterCMK's Avatar
MisterCMK
Originally Posted by quicklook2
i would check in this order: fuse, taillight bulb, brake switch.
it is probably the brake switch that is the culprit.
Yup, gotta start with the basics
Old Mar 6, 2007 | 04:16 AM
hagg26's Avatar
hagg26
I have the same problem with the brakelights on my -96 explorer. The bulbs are ok, I've changed the brakelightswitch, There is connection to the fuse which is ok, but when I meassure in the rear there is no contact. I have ruled out the connector for the trailerhitch. There seems to be a lose connection between the fusebox and the connector in the rear. Does anybody know???
Old Mar 6, 2007 | 10:39 AM
quicklook2's Avatar
quicklook2
the ground could be bad.
Old Mar 7, 2007 | 10:40 AM
hagg26's Avatar
hagg26
Check that thanx
Old Mar 12, 2007 | 07:33 AM
logan142's Avatar
logan142
my problem ended up being that one of the wires going to the brake light switch actually broke. thanks for the help on this
Old Mar 12, 2007 | 11:19 AM
quicklook2's Avatar
quicklook2
glad you fixed it and posted the fix so others will know.
LittleRedRanger4.0
Nov 15, 2012 08:02 AM
mcdrunka
Aug 25, 2011 12:22 PM
55 Merc M-100
16
Jul 5, 2008 06:25 PM
Dustin_86
Dec 2, 2006 05:40 PM
FastF350
Oct 28, 2004 08:48 PM
