brake light failure ford explorer
Old Mar 5, 2007 | 12:55 PM
logan142's Avatar
logan142
My brake lights includeing the high-mount light all went out. I checked the fuses the all seemed ok. Any other suggestions?
Old Mar 5, 2007 | 01:15 PM
quicklook2's Avatar
quicklook2
replace the fuse anyway.
it might be the brake switch.
check to make sure if you have a fuse in the power dist. box for your year model truck.
check your owners manual.
Old Mar 5, 2007 | 02:27 PM
87 XLT's Avatar
87 XLT
What are you driving? Any problems shifting out of park? If the brake light switch is bad, it wont shift.
Old Mar 5, 2007 | 02:36 PM
logan142's Avatar
logan142
I have 97 explorer xlt automatic. yeah, i couldn't get it out of park until i looked in the manual about the brake-shift interlock and how to avoid that. is the brake light switch an easy fix?
Old Mar 5, 2007 | 03:13 PM
87 XLT's Avatar
87 XLT
Dont know about a 97 Ex, but on most cars it's a simple 5 minute job to replace it.
Old Mar 5, 2007 | 03:44 PM
quicklook2's Avatar
quicklook2
replace the fuse first.
a seperate fuse works the 3rd brakelight and the fuse that works the other brake lights also controls the cruise control, anti lock brakes and the 4 wheel drive.
you have had to step on the brake pedal since the early 80's in most vehicles.
you have never driven any other vehicle that needed you to step on the brakes to get out of park?
Old Mar 5, 2007 | 04:28 PM
MisterCMK's Avatar
MisterCMK
Meter out the fuse to verify that it is functional. Chen meter out the brake light switch for continuity. Jump the brake light switch with a jumper and see if the brake lights turn on.
My Explorer doesn't require you to stop on the brakes to get out of park. I'm sure that its not supposed to be like that, but it doesn't bother me at all.
Old Mar 5, 2007 | 04:34 PM
quicklook2's Avatar
quicklook2
it is not that hard to disconnect on most vehicles.
Old Mar 5, 2007 | 04:45 PM
87 XLT's Avatar
87 XLT
From the factory wring diagrams this is how it's wired.
The one and only thing thats wired to interior fuse 13 is the brake light switch.
The brakelight switch is spliced all over the place: brake lights/shift lock solenoid/cruise control servo, etc etc.
If fuse 13 is not blown, then the brake light switch needs to be replaced.
Old Mar 5, 2007 | 05:23 PM
quicklook2's Avatar
quicklook2
fuse number 13 in the interior fuse box, a 15 amp fuse, controls according to the ford owners manual:
pcm system
stoplamps
4 wheel drive
anti-lock brake
speed control
trailer tow
Old Mar 5, 2007 | 05:30 PM
MisterCMK's Avatar
MisterCMK
Test the switch with a DVOM before throwing parts at it...
Old Mar 5, 2007 | 05:36 PM
quicklook2's Avatar
quicklook2
maybe the second time you say this it will have the desired effect.
i agree to test before throwing parts at the problem.
Old Mar 5, 2007 | 05:43 PM
87 XLT's Avatar
87 XLT
Quicklook, thats exactly right but all those items are powered from the brake light switch. They only have voltage to them when the brakes are applied.
As you said earlier this could be a blown fuse.
Logan take another look at interior fuse 13.
Is it blown??
Old Mar 5, 2007 | 06:15 PM
quicklook2's Avatar
quicklook2
i would check in this order: fuse, taillight bulb, brake switch.
it is probably the brake switch that is the culprit.
Old Mar 5, 2007 | 06:32 PM
MisterCMK's Avatar
MisterCMK
Is it blown??
They are on the same circuit. You are over analyzing this, a simple check with the DVOM will determine whether or not the switch is bad.
