EBPV Clip
Old Mar 4, 2007 | 08:56 AM
two9292's Avatar
two9292
EBPV Clip
Help, I am trying to find a source for the clip that slides over the pivot arm for the EBPV. The only place i have found it is in the pedistal rebuild kit from ford.
I MUST leave monday morning 9am where can i get one of these clips.
Old Mar 4, 2007 | 09:06 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Are you towing? Did you know, that if you do not have the EBPV wired to be used as an exhaust brake, then it is not necessary for the engine's operation. I deleted my EBPV, and i just have that connector wrapped up in tape. I know i cannot get this to you by monday, but if you want it, i can surely ship it out to you. Until then, just push the plug in the connector, and hope for the best. If it does happen to fall out, it will not cause a problem.
Old Mar 4, 2007 | 10:11 AM
two9292's Avatar
two9292
I live in michigan so i like the functionality of the ebpv. and when it does fall out then the valve starts to flutter and there goes my boost and egts.
Old Mar 4, 2007 | 10:49 AM
goin4bro's Avatar
goin4bro
I recall a post on this site where someone mentioned a substitute for that clip. I believe they got it at Autozone (or some other car parts gig). Maybe do a search like "+clip +lost +turbo" or something. If I see it I'll post again.
good luck...
Old Mar 4, 2007 | 10:54 AM
goin4bro's Avatar
goin4bro
Napa Circular Linkage clips (part number 7352640)
...per ryaneverk2
Old Mar 4, 2007 | 11:46 AM
two9292's Avatar
two9292
I found that earlier but that is for the wastegate rod. It may work though. I am going to try it let you guys know how it worked.
Also i have a ballbearing turbo, Is a banks big head necessary or is the one that comes with this turbo acceptable? Or should i just BB it?
Old Mar 4, 2007 | 02:27 PM
PowerstrokeJunkie
If the plug is disconnected, the EBPV will default to the open position. Try it.
Old Mar 4, 2007 | 04:47 PM
two9292's Avatar
two9292
The acuator rod was not connected to the ebpv. that was the clip i was missing. So it didn't matter what the actuator was telling it i.e. stay closed because i'm unpluged. the valve was fluttering in the opening because it's arm was not hooked to the rod. I replaced this clip with an e clip i'm hoping that will work.
Old Mar 4, 2007 | 04:49 PM
PowerstrokeJunkie
Oooh, sorry my mistake there. I thought you were talking about the hinging metal clip, that kept the electrical connector in it's place in the front of the pedestal.
Old Mar 4, 2007 | 05:11 PM
two9292's Avatar
two9292
Sorry probably truely my fault. i'm not very good at explaining things. I never was a comunications major.
Old Mar 4, 2007 | 05:13 PM
PowerstrokeJunkie
Are you sure it didn't fall in the valley, or down the drain hole at the back of the block, and go down beside the torque converter, and end up on the inspection plate with the weep hole? There isn't much of a place that the clip can go. Highly unlikely that it went springing out of the engine bay.
Old Mar 4, 2007 | 05:40 PM
two9292's Avatar
two9292
Unfortunately one of the prongs broke off so it would vibrate back towords the pedistal after a couple cycles of the valve.
F22driver72
May 1, 2017 10:45 AM
IH Addict5088
Apr 9, 2017 10:34 AM
bigb56
May 19, 2012 09:33 PM
Dutch Semi
Sep 30, 2011 10:50 AM
UP_There
May 13, 2011 12:49 PM
