Sponsored by: Innova
AM Radio
Old Mar 4, 2007 | 12:06 AM
fixnair's Avatar
fixnair
AM Radio
I listen to talk radio often on the AM band. I used to get a distant station fairly good then I had some transmission work done on my Lincoln. Now the reception is very noisy while the engine is running. I can no longer enjoy this station because of the static and engine noise on this channel. Any of you guys have any ideas as to what could be causing this? ANy help would be appreciated.
Old Mar 4, 2007 | 07:04 PM
ReAX's Avatar
ReAX
It's most likely RFI. Pick up a power noise filter and that should cure the problem. If it doesn't, I would suggest adding another ground to the radio and picking up a snap over ferrite suppressor.
Old Mar 4, 2007 | 11:15 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
The key here is hat you did not have the problem previously. Either a connection was not put back together properly, or some wiring was rerouted so now it picks up the noise.
Good luck!
Old Mar 5, 2007 | 12:13 AM
fixnair's Avatar
fixnair
Thanks ReAx and Aerostar. Now where can I buy these items and where do I install them in the system? I think I know what a power noise filter is but what is a " snap over ferrite suppressor"?
nisvec22
Aug 21, 2011 01:23 AM
garydmundy
May 25, 2011 11:11 AM
speersy
1997 - 2003 F150
Apr 17, 2011 09:15 PM
jawdoc
Jul 26, 2007 08:28 AM
Longone
Sep 15, 2004 08:48 AM
