1978 - 1996 Big Bronco
Big 79 Bronco
Old Aug 17, 2002 | 08:48 PM
jeandras's Avatar
jeandras
Big 79 Bronco
I own a 1979 bronco with a 460 out of a 71 Lincoln. It has an oversized cam and a 750 edlebrock carb. It has a 7 inch lift with 38.5 inch tires, dana 44 up front and ford 9 inch in the rear i believe. It has a C6 auto trans and i believe 4:10 gears in the axles. Right now the gas mileage sucks in the city but not to bad for what it is. It has 51k on the engine and 7k on the trans. I got it on the highway and at 70 miles i was reving at 3000 rpm and the tires were loud. Sounded like an airplane was behind me. Now i need to travel 4 hours from raleigh to Charleston atleast once a month. How it is now the gas will be expensive and the ride will be loud. Now if i put 33 inch alterains on the bronco how much would that affect my gas mileage and would i be able to go faster because im not lugging around the 38.5s. Would it rev higher. Or would it be better to just buy a travel car. Thanks for any input.
Joseph
Old Aug 18, 2002 | 06:25 AM
Jimbare's Avatar
Jimbare
all alone in the world
Big 79 Bronco
only one way to go, BUY A TRAVEL CAR!!! if you go smaller on the tires, you final drive ratio will fall way down low. at 70 m p h with 33s you would probably be revving around 3800-4000, not good. buy a mustang or something for gas mleage, keep the bronco for fun!
Old Aug 30, 2002 | 04:42 PM
4x4guy's Avatar
4x4guy
Big 79 Bronco
Buy a Honda
Old Sep 7, 2002 | 04:51 AM
frhoefer's Avatar
frhoefer
Big 79 Bronco
I drove my 79 Bronco from Chicago to Atlanta on 40" 6 ply Denman Ground Hawgs with a combination 10" custom lift. IT WAS BRUTAL!!!!DON"T DO IT!!!! I got 7 miles per gallon down hill with the wind at my back. I don't think it would get much better going over a cliff. It's a lot of fun, just not on a long trip at highway speeds.
Fred Hoefer
Old Sep 7, 2002 | 07:22 AM
JoeB's Avatar
JoeB
Big 79 Bronco
Brett73-79
Jan 5, 2014 06:06 PM
theguy_88
Feb 13, 2006 02:43 PM
old timer
Bronco II
Feb 1, 2005 07:43 PM
josh311
Sep 21, 2003 03:28 PM
ford_boy4819
Jun 6, 2002 11:20 PM
