Bronco II Ford Bronco II
Available Transmissions??
Old Jan 29, 2005 | 08:04 PM
old timer's Avatar
old timer
I have a 84 Bronco II 4x4 with the V6, its lifted 10", rides on 38.5" tires and has 4.56 gears. I also have a 3 speed auto trans without overdrive. I yanked out all the factory computer stuff and run a carb.
What transmissions can I swap in that have overdrive and would this be a direct bolt in?
I would really like to lower the rpms at crusing speeds and still keep all the torque it has now, so I figured this would be the way to go.
Thanks
Old Jan 29, 2005 | 10:15 PM
mrshorty's Avatar
mrshorty
I'm not the most knowledgeable about such swaps, but I will chime in with what I've seen.
About the only "bolt in" transmissions are going to be from other Ranger based vehicles. I would venture to say that the only OD transmission that leaves is the dreaded A4LD. If you get an '85 to '87 A4LD with a vacuum controlled 3-4 shift, then you'll get your overdrive, but you won't get lockup of the torque converter clutch. Later A4LD's had an electronic controlled 3-4 shift. However, with the electronic 3-4 shift, it wouldn't be hard to wire in the necessary and create a manually controlled 3-4 shift. 4R44E or 5R55E might also "bolt in", but would require even more extensive electrical work, as they are fully electroniccally controlled.
A better option might be a manual transmission with overdrive. Again, any from a Ranger based vehicle would be most likely to "bolt in"
Considering the size of your tires, you might want to consider some "non-bolt in" transmissions. Most any transmission could be made to work with enough ingenuity, money, and time.
Old Jan 30, 2005 | 06:08 AM
old timer's Avatar
old timer
Thanks for the reply. I was actually considering swaping to a manual to avoid any electrical issues, but that first auto trans you suggested may work. I will have to do some more homework as to which would be the best fit for me, but its nice to know I actually have options.
Old Feb 1, 2005 | 07:38 PM
bronco2man's Avatar
bronco2man
Smile
am looking for an automatic transmission for my 88 b2, have a 5 speed in it now, knees are starting give out and would like to find one, any suggestions,
have a 2.9 stock v6
3.45 gears
4x4
Old Feb 1, 2005 | 07:43 PM
old timer's Avatar
old timer
Where are you located? Maybe we can trade if your interested. I have everything needed to do the auto swap and I'm sure you have everything I would need.
Drop him a PM or email.
wilburn
1997 - 2003 F150
18
Mar 12, 2019 11:42 PM
mark460
Oct 14, 2016 09:05 PM
Transam461
Sep 10, 2016 12:58 PM
jmassimilla
Apr 29, 2010 05:44 AM
ralf
1978 - 1996 Big Bronco
Feb 26, 2007 01:28 PM
