another fuel guage question
Old Mar 1, 2007 | 08:00 AM
yh731801's Avatar
yh731801
1988 F-150 4.9 efi
front tank reads over full all the time, r4ar reads empty all the time. question is - is reading empty an indication of open circuit or is it a short?
Old Mar 1, 2007 | 10:34 AM
smecomark1's Avatar
smecomark1
Can't say for sure it could be that the senders have simply failed in opposite directions. Usually they fail low.
Old Mar 1, 2007 | 11:49 AM
buffalobob's Avatar
buffalobob
here in the rust belt I have found that when a fuel gauge reads way past full..its usually a lost ground because of corrosion...either on the sending unit terminal ot the frame where its grounded.........its almost a given here that old truck dont have reliable fuel gauges....fix the ground & its fixes the reading.
Old Mar 1, 2007 | 12:02 PM
wassabe's Avatar
wassabe
Sounds like my 88. Been that way since I bought it in 1995. I had it at the dealer for some work and asked them to check the gauge problem. Ended up being the sending units. I keep thinking I'll have it fixed one day, but until then I'll keep using my odometer.
Old Mar 1, 2007 | 12:15 PM
spacemn2's Avatar
spacemn2
On my 88 Mustang years ago the gauge read past full when the sender failed (open circuit). I found the sender wire in the trunk and cut it. Then spliced in a 50ohm resistor from Radioshack that cost about $2 to give the illusion that the tank had gas. The gauge then read somewhere between 1/2 and F. I believe the Ford resistance range is usually 0ohms (empty) - 75ohms (full) or so. Anyway with this test I knew the sender was bad. Bought a new one and replaced it and its worked longer than the original at this point.
HTH
88 Mustang
1/2 of a 90 F250HD
VaFordman26
Sep 5, 2013 09:37 AM
lahammer1
Jun 1, 2010 05:45 PM
cooploops
Jul 7, 2008 02:06 AM
timnish
Oct 8, 2007 09:52 AM
MTN
Feb 12, 2000 04:49 PM
