sorry to interupt your thread but could someone tell me where you find these codes lol? I have had a check engine light for years but didnt know it got more in depth than the little light
The trouble codes are stored in memory in your truck's computer (PCM). Your '99 is OBD-II ('95+) which means the codes must be retrieved with a code reader/scanner. Places like Autozone, Advanced Auto etc. will pull codes for free - just don't buy anything until you check back with us. Write them down.
Thanks for replying Alan D. The only symptoms are the CEL light is on. The truck runs fine. Looks like my first first post here is a 'stumper'?
Where did you get the codes pulled? Those particular "P" codes I've never seen before on a Ford. The "C" codes are "Chassis" codes, maybe something ABS-related.
you may want to have the codes pulled again somewhere else, or recheck the codes. those aren't ford codes. I've worked on fords for 5 years and have never seen those codes. They aren't even in the ford PCED manuel
