temp controll issue
Old Mar 2, 2007 | 01:47 PM
Alan D.'s Avatar
Alan D.
temp controll issue
Ok, i've had my heater set on high since mid january. Now i cant get it off of high. the middle **** seems to have had lost all functionallity. The blend door fix, isn't going to help me, because it is operating fine. I cant have the heat on full bore all the time. and playing with the switches got old pretty fast. So far i've found proper vacum for the system. The little acuator the conrols the amount of heat in the engine has good vaccum, and moves easily. i can manually change the airtemp when the truck is setting in my garage by pulling the vaccum hose and working the conrtoll like that, but thats not helping me when i drive down the road. Thinking maybe i need a new switch set, but not sure. any help appericiated.
Old Mar 2, 2007 | 01:49 PM
Rockledge's Avatar
Rockledge
Are you saying the blower/fan is running full blast all the time?
Old Mar 2, 2007 | 01:59 PM
Alan D.'s Avatar
Alan D.
no it's the heat. the heat wont go down from it's maximum point. it get soo hot in there, and without air, the trucks windows get all steamy
Old Mar 2, 2007 | 03:05 PM
Rockledge's Avatar
Rockledge
Why do you think it's not a blend door issue?
Old Mar 2, 2007 | 04:25 PM
ranger1999 Bob's Avatar
ranger1999 Bob
do you hear any vacuum leaks under the dash? is the blend switch loose or anything?could be the valve in the switch is bad kinda hard to diagnose tho without seeing the truck
Old Mar 3, 2007 | 07:54 AM
pawpaw's Avatar
pawpaw
I read it as, he's saying the air temp **** control isn't causing a temp change. But he can control the heaters output temp, by manually operating the under hood, heater water control diverter valve.
So, it seems to me, he needs someone to operate the in cabin temp ****, while he watches the under hood diverter valves plunger, to confirm it's not moving, when the in cabin temp **** tells it to.
SO, if the diverter valves vacuum has good vacuum on it & he says it does, if the vacuum line were removed & a external vacuum were applied to the diverter valve & it didn't move, then suspect it's diaphragm.
If it works, then look in cabin, between the control panel & diverter valve, for a vacuum leak. or vacuum control problem.
Old Mar 3, 2007 | 08:17 AM
Rockledge's Avatar
Rockledge
The water diverter valve is always open (allowing hot coolant into the heater core) except at MAX A/C. Accordingly, the valve is only actuated when the temp control **** is in the MAX A/C position.
The fact that Alan can affect the heat by playing with the water diverter valve does not mean the problem is a vacuum issue, it only means that he is letting more or less coolant flow through the heater core as he tinkers with the valve.
It sounds to me like the warm and cool air that flow through the plenum (by design) are not being blended properly.
Old Mar 3, 2007 | 09:04 AM
Ford Breakdown's Avatar
Ford Breakdown
Do the steamy windows suggest perhaps a leaky heater core? Just a WAG.
Old Mar 3, 2007 | 09:55 AM
john112deere's Avatar
john112deere
Possible, but every Ranger I've driven has been pretty prone to steaming up a bit just from breathing if you havent' got a window open a little, or the heater turned on. Pain in the butt when you don't have A/C, it's pouring buckets and 95*...
Old Mar 3, 2007 | 02:00 PM
Alan D.'s Avatar
Alan D.
YES!! this is what i've found. the blend door works fine, and is blending with **** rotation. I'm gonna order a new **** assembly and see if thats not the problem. also for the blend door fix, couldn't you glue it?
Old Mar 3, 2007 | 02:50 PM
Rockledge's Avatar
Rockledge
I think I know why I'm confused: first, you don't have A/C on your truck (right?), second, the blend door on a '97 so equipped is operated via cable.
So, if the temperature control **** isn't causing the air temperature to change, it might be because of a broken/unhooked cable.
What I stated before about the water diverter valve is still applicable, however. The valve has nothing to do with temperature control except when it it closed at MAX A/C.
Old Mar 4, 2007 | 08:38 PM
Alan D.'s Avatar
Alan D.
Rocklege- i do have a/c, and it blend door is operated by a vaccume. there are no cables running to it, and it does have a vaccum line attached to it. i know this, because if i pull it off, i can hear the system lose all it's vaccum. also i noticed that the door canges position if i pull it off.
so far pawpaws discription sounds the best as to what my problem is. the blend door is operating properly, but somehow it's not getting cool air, i have one more idea to try, then i'm rolling down to the dealership.
Edit: this is the dodge dealership, not the ford.
Old Mar 4, 2007 | 09:13 PM
Rockledge's Avatar
Rockledge
Alan, the vacuum and wiring diagrams from my '97 Ford Manual show your blend door to be electronically controlled.
http://rockledge.home.comcast.net/Ra...teControl1.gif
Why not check and see if the #10 fuse in the dash fuse panel is OK - it protects the power circuit to the blend door actuator (at least according the wiring diagram).
Similarly, the relevant vacuum diagram shows no vacuum control at the blend door.
http://rockledge.home.comcast.net/Ra...teControl2.gif
However, the vacuum diagram does show a valve that controls the outside recirculation door which is controlled by vacuum. That door is critical in allowing the all-important cool air into the plenum. So, maybe you have a problem with outside air recirculation - either the valve is no good/is not getting vacuum, or the door itself is broken. Maybe that's what you hear...
HTH. Good luck.
