msd ignition
Old Feb 26, 2007 | 01:14 PM
tradecki's Avatar
tradecki
msd ignition
I am running a stand alone ignition from MSD and would like to know if i would need a Ballast resistor, and what does it do?
Old Feb 26, 2007 | 08:19 PM
Mil1ion's Avatar
Mil1ion
A ballast resistor decreases the amount of voltage to the primary circuit of the coil.
A resistor wire in used in some 70's truck then newer shown here on the DSIII system coming out of the ignition switch.
Ford Ignition runs on 8.2 volts minimum... so, if it had 12v running to it...the coil would burn up.
I don't think MSD uses a BR (check their web site to make sure) so you you can run a 12V source to the coil key on.
http://www.msdignition.com/1ignitions.htm
Old Feb 26, 2007 | 08:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually the ballast resistor is in the RUN circuit so they can design the coil for maximum spark at the low voltage available while cranking the engine, then use the same coil to run continuously. A computer controlled ignition system can control dwell time to avoid overheating the coil. What MSD does is unknown. Check their tech department like Dennis suggested.
Old Feb 26, 2007 | 09:04 PM
Franklin2's Avatar
Franklin2
They have an excellent website with instructions on all their products.
Old Feb 27, 2007 | 12:43 PM
Mil1ion's Avatar
Mil1ion
I linked to their site in my reply above.
It's the last thing I put in it.
cchsbuzz19
Modular V10 (6.8l)
Mar 14, 2017 07:21 AM
sand1
Sep 4, 2016 07:24 PM
351Cleveland C4
Feb 25, 2016 06:43 PM
Khauler
13
Jan 31, 2011 10:28 PM
omnithesis
Apr 18, 2004 09:44 PM
