Where do I stand?
Old Mar 6, 2007 | 09:45 PM
  #46
Zwalters's Avatar
Zwalters
Originally Posted by pullinair
I'll skip the wife then, that would be a hard one to explain. Can i test the batts with this puppy? A/C right?
No, all batteries are DC. Do you know the difference? If not want to?
Old Mar 6, 2007 | 09:47 PM
  #47
John311t's Avatar
John311t
Just remember NEVER ohm something with voltage running through it, you will destroy the meter.
Old Mar 6, 2007 | 09:50 PM
  #48
Zwalters's Avatar
Zwalters
Not true, most modern meters will either have a fused circuit or a reset button when you overload it. You can replace the fuses at radioshack but it's a huge hassel, but rule of thumb is never test resistance on a live circuit or you will have to fix or reset something, which can be a hassle. If you bought a really cheap meter, it very well could destroy it, I have Flukes so they never die.
  #49
pullinair's Avatar
pullinair
YES?????????????????????
Old Mar 6, 2007 | 09:52 PM
  #50
John311t's Avatar
John311t
I like the fluke meters, when i took an electronics class(when i wanted to be an eletrical engineer long story), they had them and were much better than the cheap one i have. Im gonna buy a new meter tommorrow also, since mine is broken.
  #51
Uzumati's Avatar
Uzumati
Yea never never never set the meter on resistance and then check voltage on a 220 circuit............bad things happen - dont ask
and yes Fluke's can die i proved it .......see above
Old Mar 6, 2007 | 09:56 PM
  #52
Zwalters's Avatar
Zwalters
DC stand for Direct Current, which means a positive or negative constant stream of electricity. A/C stands for Alternating Current, which means the current switches between positive and negative at equal voltage and on a given frequency your home outlets (except for your dryer and oven) is 110-120 volts 60 Hertz(Frequency). Frequency is the number of times the voltage make a complete cycle from positive to negative and back to positive again creating a sine wave. 60 Hz or hertz means your voltage cycles 60 times a second.
Old Mar 6, 2007 | 09:58 PM
  #53
Zwalters's Avatar
Zwalters
My fluke was on resistance and I accidentally crossed 440 3phase 60hz. It lives on.
Old Mar 6, 2007 | 10:08 PM
  #54
pullinair's Avatar
pullinair
Zwalters , got it, thanks for all the info! So when i go to test my batts in the future, use the A/C function and never test something with current that is in resistance mode.
Old Mar 6, 2007 | 10:10 PM
  #55
Zwalters's Avatar
Zwalters
Us the DC mode on batteries. and everything else is good.
Old Mar 6, 2007 | 10:12 PM
  #56
pullinair's Avatar
pullinair
Thats what I meant- D/C.
Old Mar 7, 2007 | 05:07 PM
  #57
pullinair's Avatar
pullinair
I am starting to bend the ***** out of my left front quarter panel to get this wheel well liner to drop down. I have no other idea on how to manueaver it becuase it is so tight. Where the plastic wheel well liner rides on the rim of the quarter panel is where I am tight as well as wher the liner meets the frame. Am I doing something wrong?
Tim
Old Mar 7, 2007 | 05:57 PM
  #58
pullinair's Avatar
pullinair
Got my readings:
inj#1- 3.5
inj#3- 3.5
inj#5- 3.5
inj#7- 3.5
inj#2- 3.5
inj#4- 4.0
inj#6- 6.0
inj#8- 3.5
I didnt check at the valve cover yet its dinner time but I might give it a shot after dinner. When I test the Gp's you said to put a probe on the negative terminal. Did you mean the negative terminal of the Batteries?
Old Mar 7, 2007 | 05:58 PM
  #59
John311t's Avatar
John311t
You can put it on the cylinder head itself. that would be the best place to test it.
Old Mar 7, 2007 | 06:05 PM
  #60
pullinair's Avatar
pullinair
Hey John, I'm over 5 Ohm's at cyl #6. How alarmed should I be?
