vin decoding
Old Feb 26, 2007 | 01:54 PM
bgriffin09's Avatar
bgriffin09
its certainly 2 wheel drive...these are the numbers that are on the sticker inside the driver door...is there another place to look for the codes??? is there any other way to tell what type of rear end is in it? (even though its most likely 3.33)
Old Feb 26, 2007 | 01:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Tag number on the rear axle..if it's still there. It should be on one of the bolts on the back cover, or on the front of the axle on a plate.
Sample Codes: E2TE-AA or a 6 or 7 digit number like: 604000-3
Old Feb 19, 2008 | 05:52 PM
bob_351's Avatar
bob_351
are you sure this is the vin sticker for that truck. Maby its a "transplant" off another truck, people do some wierd suff
Old Feb 19, 2008 | 06:14 PM
baffledinpa's Avatar
baffledinpa
Unhappy
Very true.
I had an 85 Ford Bronco II that had 3.43 gears in the front axle and 3.73 gears in the back axle. Guess the previous owner did an axle swap and knew nothing about matching the ratios.
Pete Magnus
Modular V10 (6.8l)
Nov 7, 2016 04:09 PM
galkrin
23
Mar 26, 2014 11:12 AM
93coleman
Mar 7, 2014 09:03 AM
ford0625
1978 - 1996 Big Bronco
Jun 27, 2007 10:09 PM
69isfine
1947 and Older Ford Trucks
Mar 17, 2004 07:27 PM
