New to the site,found it very useful so far.I just bought a 92 f250 4x4 with the 351.Im trying to figure out what trans,and transfer case,axles I have,and what 351 I have.(windsor or cleveland).I tried using the vin decoder and it says my vin doesnt exhist?Has anyone else had this problem,does anyone know where I can decode my vin.My vin is 1FTHF26HXNLA34740.My door tag says trans E,axle C5,springs 5F.Any help would be greatly appreciated.Thanks, Justin
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: UNITED STATES
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: H
Brake System: STANDARD
GVWR Class:
GVWR Range: 6,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F26
Vehicle Line: F-250
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: H
Engine: 5.8 L
Cylinders: 8
Fuel: Gasoline
Engine Manufacturer: FORD
Model Year - 10th Position
VIN Code: N
Model Year: 1992
Assembly Plant - 11th Position
VIN Code: L
Assembly Plant: MICHIGAN TRUCKS, MICHIGAN
Production Sequence Number - 12th - 17th
VIN Code: A34740
Prod Sequence Number A34740
Additional Information
Wheel Axles Wheelbase 266.0
Thanks for your time KevinGnWV,much appreciated.Limited slip 4.10,SCORE!!I been doing some research on the site,and people are saying they are clearing 35s stock.Does this only apply to f350 only trucks, or will my f250 clear 35s also?Wasnt even going to try,but if I have 4.10s,I would like to.Thanks for any help,Justin
I have 285/75/16 tires on mine which are just under 33 inches and it is close. But...my truck is the supercab longbed and the front end sags noticeably. If it were level 35's would probably fit ok.
Thanks again KevinGnWV,Im looking into and add-a-leaf for the front,or a "leveling kit",but I need to do some research to see what applies to my year since I have front leaf springs.If I can find some f-350 springs for the right price,I might just switch springs.I have regular cab longbed,and it is raked considerably to the front,I notice a lot of f-350 sit close to level.
I've heard the add a leaf leveling kits make the ride super harsh, and mine rides like a 10 ton skateboard already. I'm looking at getting some +2 or similar softride springs for the front and a set of bilstein shocks all around.
Hey fellas...
I'm looking at a 1994 F150, extended cab 4x4 with an 8' bed. It has the electric 4x4 switch, (rather than a manual shift in the cab) and I assume pneumatic locking hubs.
Here's the problem.... My buddy is an Insurance guy, and he ran the vin for me. He said it comes back to a 117" wheelbase 2 wheel drive truck (due to the 5, 6, and 7th characters in the VIN being F15). He says for that truck it should be F14.
I've never seen a Ford VIN with an F14 code, and can't find a key that shows F14 as the code either.
So, for all you hardcore Ford guys out there, can you answer a couple questions?
1. The truck has 2 doors, not 4, and a back seat (extended cab) with an 8 foot bed. Wouldn't that be the long 133" wheelbase?
2. And if I read the decoder right, it's supposed to be a 117" wheelbase 2 wheel drive truck?? Could that VIN ppossibly be forrect for a 4wd truck with a long cab?
