94 Bronco won't start also where is fuel relay located?
I have a 94 EB Bronco. After putting a small amount of gas in at the station, it wouldn't start so I had to have it flatbedded home. Had already replaced the starter so I tested the ignition coil and replaced it. Also replaced the distributor cap and rotor. It started and ran fine for a few minutes now it won't start again. I would also like to know where the fuel relay is located. Thanks!
