94 Bronco won't start also where is fuel relay located?
I have a 94 EB Bronco. After putting a small amount of gas in at the station, it wouldn't start so I had to have it flatbedded home. Had already replaced the starter so I tested the ignition coil and replaced it. Also replaced the distributor cap and rotor. It started and ran fine for a few minutes now it won't start again. I would also like to know where the fuel relay is located. Thanks!
Your relay is located behind the passenger side kick panel. Put your finger in the notch at the top of the kick panel and you can push the reset down.
https://www.supermotors.net/getfile/...kennys-140.jpg |
thanks for the help.
Thanks! Turned out to be a small hard yellow vacuum line that was broken.
