Engine oil
Old Mar 1, 2007 | 06:09 PM
JenorRuss's Avatar
JenorRuss
Still my truck sits. I found a cracked battery and replaced. I had a friend check codes. I have P0266, P0603, P1378, P2614 and P2617. He suggested replacing injector #2. Does that make sense. If so where can I get a replacement other than Ford.
Old Mar 1, 2007 | 06:20 PM
diesel_dan's Avatar
diesel_dan
JenorRuss: Have you checked your oil level yet? If it's too full, the 6.0 will foam the oil and cause poor running like you are describing -- foam must play hell with the high pressure oil fired injectors, but don't know if a code would get thrown... Sure sounds like what's happening to me.
Old Mar 1, 2007 | 06:21 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
IH truck dealership should have them also a IH school bus dealership as they use the 6.0 in school buses.
K behlmer
6.4L Power Stroke Diesel
19
Oct 22, 2010 06:15 PM
JCastellaw
30
May 21, 2007 01:05 AM
FOSE88
Apr 16, 2007 06:26 PM
greenchicken
Bronco II
Apr 21, 2002 09:37 AM
55forder
Jan 24, 2002 01:08 PM
