Engine oil
Old Feb 24, 2007 | 11:25 PM
JenorRuss's Avatar
JenorRuss
Engine oil
I took my truck in for all new tires and alignment. Ended up getting an oil change as well. Drove home 7 miles it was ok. The next day it started rough, smoked white, black, sputtered, stalled, choked, bucked, kicked, settled and idled fine. Off we go. I thought new oil, cold morning, 30 degrees over night. Life is good. Drove about 40 miles two stops and knew there was a problem. When I called to speak to the jokers who did the job, they told me they ran out of Rotella and topped it off with Penzoil.
Does Pensoil make a diesel grade oil that would be ok in my truck?
Old Feb 25, 2007 | 12:17 AM
duffman77's Avatar
duffman77
Actually I have seen it in wallmart
http://www.pennzoil.com/products/LongLife/pickups.html
Old Feb 25, 2007 | 12:10 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
This sounds like the GP system wasn't working properly being your from FL. If they used 15W40 oil, sometimes it can cause a few problems when cold.
Old Feb 25, 2007 | 02:02 PM
WishIhada7.3's Avatar
WishIhada7.3
the dealer i bought my truck used from doesn not sell diesels so they IMO when they did the service they put a non diesel oil in it. 10w30 first thing i did when i got home was changed it I instantly noticed smoother running conditions in the 20 miles i had driven it.
Old Feb 25, 2007 | 04:53 PM
mrxlh's Avatar
mrxlh
Yep, Pennzoil Longlife 15W40.
Old Feb 26, 2007 | 12:05 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Their PDF file on their site states it is CI4 and not the latest CI4+ or even CJ4. Everyone else has upgraded their convential oil to be CJ4 compliant. If som your using old oil technology... not bad oil... just an old API diesel oil spec.
Old Feb 26, 2007 | 11:22 PM
Btravelen's Avatar
Btravelen
SOPUS makes Rotella and Pennzoil. I wouldn't worry about compatibility, but the CJ4 benefits would be diluted, or possibly nullified.
Take Care
Old Feb 27, 2007 | 03:16 PM
62rag's Avatar
62rag
Glad I found this thread! What is best oil to use for my 2005 6.0? The service advisor said I HAVE to run 10w-30. The 6.0 owners manual leads me to believe this is correct for my temperature range. I couldn't find any 10w-30 that had all the ratings listed in the book(CI-4, CI-4/SL, DHD-1), and Rotella was only available in 15w-40. So what do I need, or what am I missing?
Old Feb 27, 2007 | 03:48 PM
firesoutmatt's Avatar
firesoutmatt
15w40 if above 30 degrees F towing. If you tow with it go with the 40
The 6.0 shears oil faster than the others and you need the 40 .
The 30 is ok if your not towing with it.
Old Feb 27, 2007 | 03:52 PM
Brians97F250Crew's Avatar
Brians97F250Crew
I switched to Rotella Syn 5w/40 never been happier.
Old Feb 27, 2007 | 05:58 PM
duffman77's Avatar
duffman77
The best thing you can do is find anouther service advisor. They clearly do not know thier product.
Old Feb 27, 2007 | 08:10 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Check to make sure they didn't overfill your crankcase.
Old Feb 27, 2007 | 08:13 PM
mrxlh's Avatar
mrxlh
Great advice Wanabe, cannot believe we missed it til now. That should be the first thing whenever issues arise after an oil change, if you were not the one to do it.
Old Feb 27, 2007 | 08:24 PM
conger's Avatar
conger
I've been doing my own changes. I don't trust the quickie lube monkeys and the dealer's are always booked up. At least I know it's done right and I save a couple of bucks as well.
Old Feb 27, 2007 | 08:28 PM
mrxlh's Avatar
mrxlh
Conger, ain't that the truth. I cannot think of another vehicle that I have owned that is as easy to change the oil in as a 6.0l PSD. The money savings is a nice plus too.
