Bronco II Ford Bronco II
Flickering Oil Light
Old Apr 18, 2002 | 05:25 PM
greenchicken's Avatar
greenchicken
Ok here's the deal and I hope someone can guide me.
Ok I have an 88 B2 4WD XLT
112,000 Miles
Problem
This morning I started her up and heard the valves clicking
turned it off restarted and no more chattering
Drove halfway to work valves start the chatter lightly again, pull the truck over and check oil (half qt low)
restart no noise
go to work put in reverse and oil light flickers (now I am worried)
Drive home from work after adding a half qt and getting off the highway oil light flickers again.
No Noise
Oil Pump?
Or
Oil Sending Unit?
Truck has an idiot light no guages
Thanks in advance for any help you can give me.
GC
Old Apr 18, 2002 | 07:38 PM
steve_'s Avatar
steve_
id put money on oil pump or one of the parts associated to the pump my 88 b2 did the same thing when i first bought it it ran fine when i first started it but under a heavy load it started to clatter and the light came on i took it to my mechanic and he replace the oil pump wethere or not the pump itself was shot is in question but the pickup screen was 90% cloged according to the haynes manual its not that big of a job to do if you have the right tools the trick is to get the motor up high enuf to remove the oil pan which iwas unable to do with a jack and wooden blocks even though thats the way the book says to do it. im my opinion if it were just the light coming on id say its a sensor but the clatter you describe tells me its time for a pump
goodluck with it
Steve
Old Apr 18, 2002 | 08:53 PM
greenchicken
So how much is a reasonable amount to pay to have this procedure done?
Parts/ Labor
In your opinion of course
Thanks
GC
Old Apr 19, 2002 | 11:54 AM
gatorman41's Avatar
gatorman41
The oil pump replacement is a pain. You have to remove the oil pan. To do so, you have to jack up the engine and place blocks under the engine mounts. I am currently in the process of doing the same thing. This is my second time to do so on my 86 B2. After reaching in and unbolting torex bols on the pump, you have to unbolt a protective plate that blocks the pan from comming off. I can't remember where the bolts are and can not see them.
I worked on it for some 4 hours and gave up for the day. I brought in an engine hoist and will probably pull my engine as I have larger issues than just getting the pan off.
How much to pay? I don't know, but it is involved. The dist. must be removed along with the fan shroud, I believe the radiator hoses and thus the coolant drained, etc.
Note sure how much this helps. It is a good idea to get a oil pressure gauge so you know what your pressure is instead of using the idiot light. I believe I read the light does not come on unless the pressure is less than 6#s. You can be running with low pressure and not know it.
Old Apr 21, 2002 | 09:37 AM
enfer_know's Avatar
enfer_know
1968 F100 Ranger
21
Jan 25, 2015 03:53 PM
newfordy
1997 - 2003 F150
Nov 9, 2014 06:29 AM
JustDriveTwo
Sep 16, 2011 10:57 PM
azfordf100man
1997 - 2003 F150
Jul 13, 2009 05:26 PM
dburke8088
May 22, 2006 01:55 PM
