So if you're going to use the 5 on 4 1/2 CPP disc brake kit for 48-56 there is an error on the parts list. The bearing seal called for on the sheet(94065) doesn't exist. The correct part # is 9406S which thankfully does exist. Thanks to Ronnie at CPP for helping me come up with a solution. Hopefully this saves someone a call to the tech line in the future, unless you like being on hold.
Other than that, the kit looks well built and I hope to be installing tomorrow. Luckily I"ve got an old oven in my shop that I use for powdercoating. It should be quite helpful in getting the spindle adapters on.
