Blown Intercooler Pipe???
Old Feb 22, 2007 | 10:11 PM
Aggie10's Avatar
Aggie10
So I was coming home from work today and i heard this loud bang when I got around 2200 rpms...wasn't really getting on it but was blowing a little smoke. I limped on back home to find that my intercooler pipe had blown off. I put it back on and snugged all the other boots down. Is there anything else I should do or just keep checking the clamps occasionally. I figured the reason it blew off was because I just put in the TS chip so I have more boost now and the clamp just couldn't hold it.. Help please.
Old Feb 22, 2007 | 10:20 PM
Pony Power's Avatar
Pony Power
Not to worry. That's one of those "stuff happens" kind of deals. Oil film works it's way through the pipes and sometimes makes the connections work loose. A good cleaning of the pipes and connections every once in awhile keeps those events at a minimum.
It does wake you up though, doesn't it?
Old Feb 22, 2007 | 10:35 PM
hedhntr's Avatar
hedhntr
I noticed on mine if I over tighten them they just slide right up and off the fittings
Old Feb 22, 2007 | 10:45 PM
Aggie10's Avatar
Aggie10
Yea it scared the livin hell out of me...I thought I blew a head or something.
Old Feb 23, 2007 | 07:23 AM
Kwikkordead's Avatar
Kwikkordead
Something is not right here. Perhaps you need to insert the tubes a little deeper or the end of the tubes have coned out and you have to get new ones.
Old Feb 23, 2007 | 07:43 AM
Pocket's Avatar
Pocket
I agree with Kwik, those boots have to be clamped on tight. When I put the 6.0L intercooler in, I didn't get a new clamp for the 3" inlet, and instead used the 3.25" clamp on the boot. Thought it was fairly tight and snugged it down. On the test drive it blew off at only 15 psi. Learned my lesson: snug doesn't work. Now I've got a 3" clamp on there and it holds 30 psi without a problem.
num1husker
Jul 12, 2010 07:08 PM
Epd444
Jul 28, 2009 08:34 PM
IDPisan
Nov 9, 2008 10:14 PM
7.3 Powerstroker
Apr 1, 2008 03:47 PM
RubberDuck
Oct 31, 2006 08:48 AM
