Blown intercooler pipe.
Old Mar 31, 2008 | 07:37 PM
7.3 Powerstroker's Avatar
7.3 Powerstroker
Had just got a new set of boots from diesel site. Well the other day i had got on it and i heard a pop and then no boost so limped it home and took a look. It had blown the intercooler pipe clear out of the boot. So is there any suggestions on how to keep this from happening again double clamping the boots maybe. I had also painted the pipes with the install of the new boots. Any suggestion would be appricated. Thanks.
Old Mar 31, 2008 | 07:45 PM
zx250's Avatar
zx250
Of the next Riffraff East
Could be a simple issue of not having it slid on far enough or clamped tight enough. Clean it good and some spray some hairspray on it before reinstalling it. Tighten everything up good and try again. Shouldn't have to do anything special.
Old Mar 31, 2008 | 08:38 PM
bigsteve1969's Avatar
bigsteve1969
did it to me the other night after foil delete and i just loosend up that clamp and moved it back a lil' ways and i shoved that pipe in there as far as i could then tightend it back with a 1/4 inch ratchet to keep from over tightn it. i can feel about 1/2 inch or more of pipe INSIDE the boot. i've checked it every day just to make shure. I have heard about the hairspray and it does work
Old Mar 31, 2008 | 08:43 PM
F350-6's Avatar
F350-6
If you just blew the pipe out of the boot, bigsteve has the right idea. Clean everything up real well and apply hairspray before reassembling (having a 19 year old daughter I'm set in this department). Check all 6 of your boots periodically. I recently discovered some loose CAC boots on my truck.
Old Apr 1, 2008 | 12:28 PM
7.3 Powerstroker
Thanks guys i'm gonna do the hairspray idea.
Old Apr 1, 2008 | 01:22 PM
duck fan's Avatar
duck fan
Because racetruck
Forgive me for being a complete rookie but where are the other two? The reason I ask is I suspect I have a boost leak and checked the 4 this weekend. Just wondering where else to check....
Old Apr 1, 2008 | 01:59 PM
F350-6's Avatar
F350-6
There's 2 on top and easily visible. Two down by the radiator at the the other end of the tubes, and the last 2 are underneath the spider (y-shaped thing with the top boots that are easily visible. The last ones are the hot side and take a 5/16 bit to tighten them. They are supposed to be Orange, but mine were camouflaged in a nice layer of oily gunk.
If that doesn't help let me know and I'll post a pic.
Old Apr 1, 2008 | 03:37 PM
duck fan's Avatar
duck fan
Because racetruck
A pic would be awesome. I am at the office and will not have a chance to look at my truck till later. A pic is a good visual reference for later. Thanks again!
Old Apr 1, 2008 | 03:43 PM
F350-6's Avatar
F350-6
Well I'm sure you've found these 2
The orange ones are below that and clamp on to the motor so to speak
There's one on both the passenger and driver side. My passenger boot clamp was barely finger tight.
Old Apr 1, 2008 | 03:47 PM
duck fan's Avatar
duck fan
Because racetruck
I will look at those tonight. I have this sound that others on the board have led me to believe is a boost leak somewhere. Its something between a shh, shh, shh sound and a tick, tick, tick that increases in tempo with RPM. Plus I got a P1249 Wastegate steady steady state test fail code.
Crazyotto1
Nov 13, 2014 04:55 AM
Excurvelle
Oct 13, 2014 09:22 PM
golfmedik
6.4L Power Stroke Diesel
Feb 27, 2013 11:22 PM
Pocket
22
Nov 10, 2012 08:12 AM
1L243
Jul 13, 2012 06:43 PM
