Sponsored by: Real Truck
2004 F250 driver side mirror replacement
Old Feb 21, 2007 | 07:36 PM
SuperDutyDadF250's Avatar
SuperDutyDadF250
I have the small "car" type side mirror and busted it today. I have the replacement part and the mirror removes easily. However, the cabling will not pull up and allow me to disconnect with just the mirror removal. It appears that I will need to remove the door panel as well. I cannot find any screws, however, reasonable pulling on the door panel also does not remove the panel completely. I'm nervous I'm going to break something. Can anyone tell me how to remove the driver's door panel on an F250 SD, 2004, 4 door, 5.4 Triton?
Old Feb 21, 2007 | 08:11 PM
RJB1's Avatar
RJB1
welcome to FTE. If you look at the tech folder at the top of the page it describes mirror replacement and door panel removal..
Bob
Old Feb 21, 2007 | 08:46 PM
SuperDutyDadF250
Thx, I will try that. However, I did figure it out. The clips requiring lifting upward and I found the wiring harness connected and mounted behind the panel (near the inside door handle) and was able to finish the job. Remember to tie a string to the wiring harness. It is very necessary to clip up the new wiring.
LifeIsGood85383
22
Jun 16, 2019 08:11 PM
Killer RC
24
May 13, 2015 05:24 PM
narrowfarm
Oct 16, 2014 09:22 PM
FireFerret
1997 - 2003 F150
Jun 30, 2014 11:39 PM
rr04-150crew
2004 - 2008 F150
Sep 6, 2007 07:26 AM
