Removing door panels to replace mirrors
Old Apr 5, 2011 | 07:25 AM
Killer RC's Avatar
Killer RC
I installed towing mirrors on my 2010 E350 today. Since they are power mirrors I had to remove the whole door panel to get to the wiring plug. Removing these door panels is easy to do if you've done it before, but its frustrating if you've never done it. So I figured I'd take some pics of the process.
1- Pull on the top of the black sail. It will pop loose. Then lift up and off.
2- Remove black screw behind sail
3- Remove black screw at bottom corner of door
4- Remove black screw behind door handle
5- Pull up on the window/door lock control panel. It will pop loose.
6- Reach down through control panel hole and push out the trim panel around the door handle.
7- Remove black screw on metal plate. There should now be 4 black screws removed from the door.
8- You should now be able to just lift the door panel straight up and off. Then unplug your power mirror wiring from the switch on the door panel.
9- Unbolt the speaker. Reach through the hole and pull the mirror wiring plug out and disconnect it.
10- Now you just unbolt the mirror and pull the wiring out of the door. Then reverse the process with your new mirror.
Check out the difference. Even when fully pushed in, the towing mirrors stick out probably 4" more than the stock mirrors.
BTW, the Ford dealership wants $700 for a pair of mirrors, so I got some non-OEM mirrors online. I got these telescoping power towing mirrors for $203 shipped. AM Autoparts - After Market Auto Parts - Headlights, Mirrors, and More I'm very happy with them so far. They have a cast metal frame inside. They weigh probably twice as much as the stock mirrors. The quality looks as good as OEM mirrors. I can't tell the difference. These might even be better than OEM.
Old Apr 5, 2011 | 12:09 PM
redtanrt10's Avatar
redtanrt10
Thanks for posting, I'm sure you"ll save folks a ton of time by seeing your thread.
Your van looks great too. What does the "hpi" on your plate mean, happy?
Mike (VPR TOWR)
Old Apr 5, 2011 | 02:32 PM
Killer RC's Avatar
Killer RC
Hobby Products International. It's what pays the bills. I make aftermarket upgrade parts for gas R/C cars and boats. KillerRC.com - Home of Killer R/C Parts
Old Apr 5, 2011 | 05:14 PM
firepop5's Avatar
firepop5
Are your stock mirrors for sale?
Old Apr 5, 2011 | 05:19 PM
Killer RC's Avatar
Killer RC
I'll probably keep em.
Old Apr 5, 2011 | 08:01 PM
SilverE350's Avatar
SilverE350
You said, in another thread, that you had ordered a F Series grill. Will they fit? Are you after the "Super Duty: embossed on the top of it or some other reason? I want to go with a Black one.
Old Apr 5, 2011 | 08:42 PM
Killer RC's Avatar
Killer RC
I just like the embossing. I hope it fits. We will see.
Old Apr 5, 2011 | 08:48 PM
SilverE350's Avatar
SilverE350
That would look sharp. I was thinking of putting the "E 350" rear badge on either front fender like on the F's. The E 450's had one there.
Old Apr 5, 2011 | 08:50 PM
Killer RC's Avatar
Killer RC
I was thinking about totally removing all the badges. LOL. Its easier to wash and wax without em.
Old Apr 6, 2011 | 06:25 AM
JWA's Avatar
JWA
There's a set and one left side for sale in the Classified section here---some guy named JWA I think..................
PM me if interested-----sorry if this is blatant cross posting or otherwise not well advised!
Old Apr 6, 2011 | 12:53 PM
Travelin'Jones's Avatar
Travelin'Jones
Wonder what would be involved in getting the Excursion/F350 telescoping mirrors With Turn Signal Lights in them to work on our E350?
Old Apr 6, 2011 | 01:12 PM
Killer RC's Avatar
Killer RC
I thought about the same thing. I'm not sure that the "Sail" part of the mirror mount is the same shape. I think the van doors are shorter and the mirror mount might be narrower too. I need to park my van next to a F250 and compare them.
Old Apr 6, 2011 | 06:04 PM
Killer RC's Avatar
Killer RC
I just got a close look at the mirrors on a 2011 F250 and they will not fit on an Econoline. The base area is too big. Not sure about other years though.
Old Apr 8, 2011 | 02:22 PM
Killer RC's Avatar
Killer RC
The F250 grille doesn't fit. Totally different mounting and shape. Guess I'll resell it.
Old Apr 10, 2011 | 07:54 PM
RICKWV's Avatar
RICKWV
Killer,
Thanks for the instructions and pictures (Marine Luv Pictures). I put mine on this afternoon with no problem even with my nieghbor helping. I can't believe the difference in vision in the normal position let alone towing.
I would send pictures but just look at your's and think no license plate.
Thanks Again
RickWv
