Sponsored by: Real Truck
key switch does not turn off blower
Old Feb 21, 2007 | 07:03 PM
kevin22602's Avatar
kevin22602
When I cut off the truck, the blower motor continues to run. Also, my speedometer, odometer has quit working all on the same day. I did not have any issues last night when I cut the truck off, and this morning is when it started messing up. When I start the truck, sometimes it dings 3 times just like when you cut it off while still rolling. Does not do this at every start up. This is a 2000 350 w/ 7.3 powerstroke. Any help is appreciated....
Old Feb 24, 2007 | 09:38 PM
ReAX's Avatar
ReAX
I think your GEM is screwed. It's not powering up your speedo/odo and is not powering down your fan. The dealer can scan for body codes to be sure, if they can't connect, then it needs to be replaced.
Old Feb 24, 2007 | 10:10 PM
99f350sd's Avatar
99f350sd
The gem doesn't have anything to do with either. Check for blower relay sticking. Any more sysptoms on the speedo?
Dick
Old Feb 26, 2007 | 04:05 PM
kevin22602's Avatar
kevin22602
Pickup cured itself. I'm guessing all the standing water from melting snow has alot to do with it. The day after it stopped, the speedometer started working again. 2 days later, the blower was back to normal. I know the relay to the the blower is ok, I swapped it out the next morning, still the same thing. I had to replace it a few years ago as my cb radio was spliced into the same circuit. Ofcourse the radio is hopped up and draws alot of power and it caused problems before. That was re-wired differently at that time. We just got 7 more inches of snow yesterday, so I'll see what happens this time.......
Old Feb 26, 2007 | 05:26 PM
1buzzbait's Avatar
1buzzbait
Originally Posted by kevin22602
Pickup cured itself. I'm guessing all the standing water from melting snow has alot to do with it. 7 more inches of snow yesterday, so I'll see what happens this time.......
--there ya go-ya got water seeping into your fusebox i betcha if ya pull it it will be full of green fur!!!
CABGx3
Jan 9, 2024 05:24 PM
jmccann698
Feb 27, 2015 07:47 AM
jprix
Dec 3, 2013 03:08 PM
backdraft341
Jun 9, 2010 07:30 PM
kevin22602
Electrical Systems/Wiring
Mar 23, 2007 06:21 PM
