electrical Woe's
Old Feb 21, 2007 | 09:52 AM
aj197816134's Avatar
aj197816134
electrical Woe's
Last Week while running the 86F250 5.8 C6 the lights on the entire truck started to blink or surge in a uniform rhythm, they never go out but go light dim light dim. Any ideas.
Also I am thinking of going to the 3G alternator set-up if possible. My Alternator is lower on the engine, Had AC at one time, What Alternator would work for the 3G series, Any suggestions
Allan
Old Feb 21, 2007 | 11:47 AM
white rose's Avatar
white rose
I would check the headlight switch.
Old Feb 21, 2007 | 01:03 PM
Franklin2's Avatar
Franklin2
Take a short piece of wire and bolt it to the engine block(scrape the paint away). Then take the other end and bolt it to one of the bolts holding the alternator regulator. See if that makes it go away.
Old Feb 21, 2007 | 04:31 PM
paden's Avatar
paden
I agree with Franklin2, check your engine and chassis grounds.
Old Feb 21, 2007 | 09:42 PM
aj197816134
I will do that tomorrow, Thanks, would make sense, I know its something dumb or simple. I am going to do the HeadLight Relay Add.. just makes sense.
Dodger12
Nov 18, 2014 01:13 PM
Allan Friesen
Dec 23, 2013 05:45 PM
hreyesg
Jul 17, 2013 07:47 PM
oldmerc
22
Mar 27, 2012 09:02 PM
oldmerc
Nov 27, 2011 08:46 AM
