I am new to this body style though I do have a 74. I am wanting to tweak the torsion bar to raise the front end to be level with the rest of the truck. Once I have done that can I fit a 265/70/17 on it. I have a 2003 2wd King Ranch Screw. Thanks for your time and have a great day.
I used the Fabtech 3.5" lift spindles in the front with 2" blocks in the rear. This allowed me to clear 285/75/R16 with minor trimming on the front. As far as using the spacers you should be able to clear 265/70-17.
I really like the extra height with the spindles and blocks....just a thought
My KR came with 275/60R17 tires as original equipment.
Yeah that is what mine came with also. I am wanting to level the truck out and personlly feel that the KR looks better lifted than lowered, but what are you guy's thoughts. I have looked into both and to lower the rear would be cheaper but not sure if it is the look I want to go with.
with 3.5" lift spindles on the front I had to trim to make room for 285/75/16's. These are 32.9 in tall and about 11 or so inches wide. Mine is 2wd also
