cam position sensor and throttle position sensor at the same time?
Old Feb 20, 2007 | 10:05 AM
BigHazard's Avatar
BigHazard
Cool cam position sensor and throttle position sensor at the same time?
ASbout 2 days ago me and big hazard were cruizin down the road and she just died. I thought it immediatly CPS. check engine light comes on. SO yesterday I am cruising into the drive way get out get the mail and get back in and it wont move. I notice my fuel guage isnt working. SO I get the programmer out and run it and it comes back wil CPS and TPS with about 6 other codes I havent researched yet. Any one ever heard of this happening? Both at once plus the gas guage. Wrote down the other codes but forgot them at home.
P.S. got my new 39.5's on and posted a couple of pics... check em out
Thanks
BigHazard
Old Feb 20, 2007 | 03:01 PM
Uzumati's Avatar
Uzumati
Post the other codes when you gat a chance so we can see if anything is common about them, I'm thinking electrical gremlin.
Old Feb 21, 2007 | 07:49 AM
BigHazard's Avatar
BigHazard
Wink Coincidences
Coincidences would be the word of the day. I was getting a waste gate code. 2 low voltage to the pedal sensor. CPS code and when it all came down to it. It was a blown fuse (I think). The big issue with my truck is it’s a rebuild. I built it and it’s my first with a complete wiring harness swap (swapping 2002 harness into a 1999). So yesterday I went and got a pedal and it didn’t work. So I started searching through the dash and under the hood for loose dirty connectors and my cousin found a bad fuse under the dash (we pulled them all 1 by 1). I think I had changed that very fuse the day before and it blew again. Meanwhile I had disconnected both batteries (system reset). When we put the batteries back in-line. She fired right up. I am still getting my waste gate and cps codes and that’s on the agenda for this evening. Thanks for the effort and sorry to waste your time.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Big Hazard
BigHazard
Projects
29
Jan 26, 2018 09:45 AM
johnsps250
Dec 21, 2016 07:48 AM
duggyb
15
Mar 8, 2016 07:45 AM
BigHazard
Nov 14, 2015 01:30 AM
Hussler
Sep 19, 2015 03:54 PM
