Bellhousing ID
Old Nov 13, 2007 | 05:59 PM
dirtyoffroad's Avatar
dirtyoffroad
Bellhousing ID
I'm going to use this bellhousing#D9TA-7505-BA,it was bolted to a 429,but I want to use it on my 460,will this be OK?also I need to replace the aluminum seat that the clutch fork pivots on,it is held on with 2 torx screws,appears to be worn off center,no #'s on it.
Old Nov 14, 2007 | 09:55 PM
385seriesHemi's Avatar
385seriesHemi
Yeah should be able to work fine. The casting code on it D9 makes it a '79 model year and was probably used on 460, 351M or 400. 429, 460, 351M, 400, 370 have the same bellhousing bolt pattern
rigsboo
Nov 18, 2016 10:09 PM
rattrucker
Sep 29, 2013 10:48 PM
F350moneypit
Aug 18, 2013 01:50 PM
chloichina
May 23, 2010 07:35 AM
swolh
19
May 17, 2010 10:01 AM
