428 crank
Old Feb 19, 2007 | 10:20 AM
highboy390fe's Avatar
highboy390fe
428 crank
I am looking into building a 390 and putting a 428 crank in it and i have a quick question can i use my 390 rods with the 428 crank or do i have to get 428 rods to. I thought you could use 390 rods and it will be a 410, am i think correctly or not thank you.
Old Feb 19, 2007 | 10:28 AM
rusty70f100's Avatar
rusty70f100
Yes, this is how Ford built them from the factory. There are only two lengths of FE rods; 6.54" and 6.488". The 6.54" was only used on the 332, 352, 360, and some FT's. The 6.488" rod was used on everything else.
The difference is the pistons. You'll want ones with an approximately 1.68" compression height. Look for 390 truck pistons.
Old Feb 19, 2007 | 02:03 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Also the stock 410/428 flywheels are external balanced. You can either use external balance or have the crank neutral balanced with a few slugs of mallory metal. Maybe think about ARP rod bolts for your 390 rods if your doing more than a stock rebuild.
Now is a good time to look for a 428 crank. New forged steel stroker cranks are out (no 3.98 tho) and that's pushed the prices down a little on the Scat cast iron stuff. And that trickles down to the oem 428 cranks a bit cheaper now if you shop around. Flatlanders sells the Scat 3.98 428 cast crank for $579 new. Good used oem 428 cranks are $300-450 depending on the under grind.
G.
Old Feb 19, 2007 | 02:32 PM
highboy390fe
I am shopping around right now for a 428 crank, i have found a few for about $400. I also have another question for you I plan on probably running a 941 cam with C8AE-H heads and aluminum edelbrock or "S" code intake and will be running it in my 73 f250 strickly mud truck w/ 44 inch boggers and would like to run farely high compression. what pistons do you guys recommend running and what kind of compression will i be running. Thanks
Old Feb 19, 2007 | 03:42 PM
rusty70f100
What octane fuel will you be running? Race gas, pump gas, E85...?
Old Feb 19, 2007 | 04:11 PM
highboy390fe
I would like to keep at no more than 93.
Old Feb 19, 2007 | 05:00 PM
rusty70f100
Either Ross #99602, or Federal Mogul 381P. Although I dont like the .030" deck clearance the 381P gives with this combination, and Ross's pistons aren't free...
Really though, call up Barry at Survival Motorsports. I think he can get some good pistons for this combination.
http://www.survivalmotorsports.com/
Old Feb 20, 2007 | 02:54 PM
highboy390fe
Thanks I will give him a call.
Old Feb 20, 2007 | 03:15 PM
highboy390fe
I have another question for you guys to, i have the C8AE-H heads with the 14 bolt exhaust and a set of D2TE-A. I will be bringing the heads in soon to the machine shop and want to put in the CJ Valves what are the better heads that you guys would go with, and what size are the CJ Valves I thought there were 2.09/1.65? Thanks
Old Feb 21, 2007 | 06:21 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Build the D2 heads..they have a larger port.... and yes 2.090/1.650 are CJ size! And I word go with the Edelbrock RPM intake..It seems to have a pretty good torque curve!
RJ
Old Feb 21, 2007 | 09:23 AM
rusty70f100
What? I thought the C8AE-H and D2TE ports were identical, the only difference between the two heads being hardened exhaust valve seats in the D2TE and later heads.
I'd say go with whichever heads need the least work. Look for warpage, excessively worn guides, etc.
RustyTrustyF150
Feb 7, 2005 04:17 PM
led sled
55
Jul 25, 2004 05:08 PM
fordman428
Jan 19, 2004 12:34 AM
Jackflack
Nov 3, 2003 09:32 PM
Roach1161
May 12, 2003 06:05 AM
