428 crank in a 390 ???
.080 over is too much for most 390 blocks. Have your block checked to see if it will handle that.
At 390 bore of 4.05 or at .030 over 4.08, you can build a 410 using the 428 crank.
Use the search feature in the FE forum to find more info on these builds. It may require 428 rods and custom pistons.
here is a good thread on 410 pistons. I found many threads just looking for 410 in the FE forum over the past year.
https://www.ford-trucks.com/forums/s...ght=%25252B410
The other thread describes the pistons I was able to find.
What you want is 410 Merc pistons. (which were also used in late model trucks.)
Trouble is thay are only readily available in cast.
If you want forged, your options are either "Custom" (Ross catalogs one, but its basically a catalog custom) or machining a standard 390 piston.
HTH
HTH
Turn your 390 Into a 428
Look for a D3TE block used in some 73-76 360/390 pickups. The block has the thick main webs similar to the 428CJ block. It also has thicker cylinder walls than the standard 390 block. We have successfully bored several customers D3TE blocks .080" over (428 standard) without problems. If you are unsure, have your shop sonic test the cylinder wall thickness.
bshackelford711
05-19-2005 09:47 AM
77fordguy
02-15-2005 08:36 AM
mike390
08-08-2004 06:21 PM
led sled
55
07-25-2004 05:08 PM
galaxie64
02-22-2004 08:03 AM
