Bronco II Ford Bronco II
Distributor gear
Old Feb 19, 2007 | 12:11 AM
Canadianice's Avatar
Canadianice
Distributor gear
I was woundering if anyone has advice on how to pull the gear of the bottom of the distributor? I have an 84 BII and am rebuilding the distributor and am having a hard time taking this thing off so I can replace my distributor pickup.
-thank you
Old Feb 19, 2007 | 06:57 AM
kotzy's Avatar
kotzy
Unless you have something very unusual all that should need to be done is remove the pin holding the gear and then take a light hammer and a block of
hard wood and drive the shaft out of the gear. You may be able to take the distributor in your hand and with the block laying on the bench pound the end of the shaft on it and it should come off. Never really saw any that were very tight.
Kotzy
See following post.
Old Feb 19, 2007 | 07:04 AM
kotzy's Avatar
kotzy
Hold on a minute I don't think you want to take the gear off. Clamp that distibutor in a vise, get two medium screwdivers under the reluctor or trigger wheel. It should pry up real easy. There is a locator pin under it don't loose
it. Now you can get the plate out and do your work. Peplace the trigger wheel
by getting it lined up and light hammer and punch back on.
Kotzy
Old Feb 19, 2007 | 07:57 AM
kernel-panic's Avatar
kernel-panic
The gear comes off. It's held in place by a roll pin. Remove the roll pin (will probably take a small drift punch or drill bit) and then tap the gear off the shaft end. I don't recall ever seeing a Ford distributor that the gear didn't come off the end of the shaft, but it's been a while since I rebuilt a points-style or Duraspark-style distributor.
Old Feb 19, 2007 | 03:02 PM
Canadianice
thanks for the quick replies, I will try the block of wood method first, I just have to be careful not to damage the gear.
Old Feb 19, 2007 | 07:58 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Sometimes they are really, Really stuck on there!
Old Feb 20, 2007 | 01:13 AM
kernel-panic
Yeah, I ended up putting a new gear on a distributor I rebuilt.... and I'm just going to leave it at that
1990-f250
Mar 24, 2014 08:54 AM
RadioControlGuy85
Mar 9, 2014 02:19 PM
64fordf100292
Mar 16, 2007 04:11 PM
nevereverquit
Dec 29, 2003 06:59 PM
