fluid capacity
Old Feb 17, 2007 | 01:58 PM
MAKO314's Avatar
MAKO314
fluid capacity
what is the fluid capacity w/o tc
Old Feb 17, 2007 | 05:10 PM
AustinS's Avatar
AustinS
Since no one has responded to your post, I'll give you as much info as I can. Total capacity depending on tranny cooler is 17.1 qts. w/20 plate cooler & 17.6 qts. w/26 plate cooler. The 4R100 stock torque converter holds 6.5 qts. So 10.5-11 qts. depending on your pan depth and cooler size.
Hope that helps,
Austin
SuperDoodie
Oct 21, 2011 06:57 PM
Fitzgerald_welding
Feb 13, 2010 10:45 PM
heathrunkles
Feb 23, 2008 01:14 PM
karljay
Mar 20, 2001 10:51 AM
