Sponsored by: Real Truck
VSS Wire Location
Old Feb 17, 2007 | 10:11 AM
PeterNLois's Avatar
PeterNLois
VSS Wire Location
I have done a search and didn't find what I was looking for. I was hoping someone could tell me the exact location of the VSS wire in a 2004 F-350. I am trying to hook up a nav unit and I need to splice into the VSS for it. Thanks for any help you can provide.
Old Feb 17, 2007 | 10:52 AM
shockwave6's Avatar
shockwave6
Gray with a black stripe at pcm
Old Feb 17, 2007 | 02:22 PM
7.3 Ex's Avatar
7.3 Ex
The VSS plugs in to the top of the rear axle differential.
Old Feb 17, 2007 | 05:54 PM
RickF350's Avatar
RickF350
https://www.ford-trucks.com/forums/5...reo-wires.html
Old Feb 17, 2007 | 06:45 PM
PeterNLois's Avatar
PeterNLois
The factory harness in my '04 does not look like that one. I do not have a gr/blk wire in it either. I am guessing that I will have to run a wire into the engine bay to the PCM unless anyone knows where it might be under the dash? Thanks for the replies.
Old Feb 17, 2007 | 09:05 PM
shockwave6's Avatar
shockwave6
it also goes to your instrument cluster same color middle connector
Old Feb 17, 2007 | 09:26 PM
7.3 Ex's Avatar
7.3 Ex
Perhaps you could use a GPS unit for speed. The factory Ford PCM is usually at least a couple miles per hour off anyway. Just a thought.
Old Feb 17, 2007 | 10:00 PM
shockwave6's Avatar
shockwave6
He is installing a nav system that uses GPS. The nav systems needs the VSS signal to more accurately track position by using GPS info and the VSS signal for better accuracy
Old Feb 17, 2007 | 10:15 PM
99f350sd's Avatar
99f350sd
What you need is the modified signal. Not the one that comes from the sensor. It has to go through the ABS module if I remember correctly to get modified then goes here and there. I don't have data on the 04. Sorry
Dick
madsonp
Sep 19, 2017 05:02 PM
svtman99
18
Feb 21, 2015 07:13 AM
feistelp
Jun 19, 2014 05:30 PM
Able_landscape
Mar 11, 2014 06:27 AM
wire4money
Mar 14, 2009 06:01 AM
