I need help removing the key switch from my 1997 F150. I had just replaced it about two weeks ago and the darn thing is stuck on the off position. I know that the only way I was able to remove the old one was to have the switch on the on position. Since it would turn to the on position, I can't get that button to push in........please help!
Sometimes you can get lucky and turn the key if you tap on the end of it with a small hammer and then try it.
If that doesn't work you may end up drilling out the lock cylinder and that's not much fun at all
