Ignition Harness Missing Help 77 F150
Old Oct 4, 2012 | 04:29 PM
Lordeklund's Avatar
Lordeklund
I have a 1997 F150, 400M. The ignition Key and harness where removed by someone and now trying to replace, I bought the Key, the Ignition Switch, but no ignition harness is available. If some one can give me info on what color wires connect to the 6 pins on the switch that would be great. thanks.
Old Oct 4, 2012 | 04:56 PM
jim collins's Avatar
jim collins
Do you have a 77 or 97 ? you name both and Ford never did build a 400M ,just 400, they did build a 351M.
Old Oct 4, 2012 | 04:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
This is the ignition switch plug from a '75.
Also, you can go here to get the factory wiring diagrams.
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
They don't have the '77 yet but you can use the '76. You want page 3 section D8.
Old Oct 4, 2012 | 05:42 PM
Lordeklund's Avatar
Lordeklund
It is a 1977 LOL. not 97, the problem is that 77 has 6 pin and all the rest had 10 pin.
Old Oct 4, 2012 | 05:46 PM
Lordeklund's Avatar
Lordeklund
I don't have the Gray part that the wires go into. So I may have to connect right to the ignition switch. it shows on the back of the Switch, Batt, P1, P2, ACC, ST and T1 wire posts on the back, what color wires connect to each.
Old Oct 4, 2012 | 06:06 PM
Lordeklund's Avatar
Lordeklund
[IMG]file:///C:/Users/admin/Desktop/F150/underdash/loosewires.jpg[/IMG]
Loose wires under dash.
Old Oct 4, 2012 | 06:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The link you posted won't work. That justs shows the location of the picture on your hard drive.
Click on the link I posted to Fordification.net and go to the '76 wiring diagrams, page 3. At the bottom of the page are information boxes. Look at the box marked C-412, this is the layout of the wiring for the ignition switch.
Imallearsfor59s
Oct 13, 2018 04:34 PM
highguy2012
May 2, 2012 11:51 PM
breakfree
Apr 2, 2006 12:41 AM
fordman954
Jun 3, 2004 11:53 AM
