I had replaced the key switch in my daughters truck and the darn thing is stuck in the off position again. I understand that it needs to be in the on position in order to remove it......please help. I can't get the button up in order to slide the switch out of the cylinder.
Welcome to FTE, nice to have you on board.
Here is the link to the FTE forums: https://www.ford-trucks.com/forums/index.php
For tech replies post in the 1997 - 2003 F150 forum, be sure to drop into your local Ca chapters.
