96 F 150 key switch
Old Feb 6, 2009 | 08:13 AM
campbells111's Avatar
campbells111
96 F 150 key switch
I need to remove the key switch and replace it. The problem is that the cylinder wont turn so I cant remove it. I know I have to have the key turned to be able to depress the button that releases the lock cylinder. How do I remove it with the key in the off position? HELP I NEED MY TRUCK TO GO TO WORK!!!!!!!!!
Old Feb 6, 2009 | 09:29 AM
donjamer's Avatar
donjamer
Campmpbells111 Welcome to the FTE site..
Not sure of how to fix your problem, but try and post it in the 87-96 F150 forum and I am sure there is someone there who can help. it is located here https://www.ford-trucks.com/forums/forum28/
Also take a few minutes and join your local MA chapter..
You can click on the link in my signature and follow the instructions..
Check out the MA Chapter here. https://www.ford-trucks.com/forums/forum226/
Again welcome aboard..
Jstkatt
New Member Introductions
Nov 2, 2017 09:38 AM
lorenlyon
Nov 16, 2009 07:37 PM
mick2
Jan 12, 2008 04:56 PM
mswenson
Sep 30, 2007 03:59 PM
