1978 - 1996 Big Bronco
vacuum modulator question
Old Feb 16, 2007 | 04:38 PM
bbgot's Avatar
bbgot
I have a 78 bronco w/ a 351/c6/np205 with the stock motorcraft 2150 carb. I recently noticed that the hose coming from the vacuum modulator is just hanging loose. Do I connect this to a vacuum source at the carb or intake manifold? Thanks for any help.
Old Feb 16, 2007 | 04:49 PM
rjent's Avatar
rjent
You are probably experiencing high shift points as well. The vac modulator simply needs to see vacuum. Hook it to a straight vac port and you should be good to go. The transmission needs to "know" how hard the engine is working to override the govenor pressure!
Hope it helps
Old Feb 16, 2007 | 04:52 PM
kenpobuck's Avatar
kenpobuck
I'm sure it connects to the carb. Check for a vaccum port that is open. the truck should run better once it is hooked back up as this would fix a vaccum leak.
Old Feb 16, 2007 | 04:57 PM
bbgot's Avatar
bbgot
thanks for the help. this truck had several of the ports on the carb plugged when I got it so I'll bet that one of those ports i the one I'm looking for.
Old Feb 17, 2007 | 02:16 PM
alxsnmr's Avatar
alxsnmr
Actually, most of the late seventies cars that had the c-4 or FMX that I drove had the vacuum port off the vacuum tree shared with the brake booster. That was a direct port off the manifold if I remember right. You will want a port that has constant vacuum not regulated by the carb operation. The tree on my 78 351M comes off the back of the manifold and some people here recommend against using vacuum off these ports because it causes lean conditions in the number 4 and number 8 cylinders.
mos68x
15
Feb 7, 2021 04:52 AM
dtkkc
Sep 23, 2016 04:49 PM
RileyCarroll
Jul 29, 2016 04:01 PM
grandpas1974
Apr 8, 2016 11:34 AM
Carmax
Nov 24, 2015 09:34 PM
