460 vacuum line question
Old Apr 1, 2006 | 04:38 PM
dtkkc's Avatar
dtkkc
I have a '77 non egr 460. There is something(sorry not sure what its called) screwed into the back of the intake manifold. It has two vacuum ports on the passenger side(one goes to my transmission modulator) a big port at the end and a single one on the drivers side. My question is, what does the vacuum line from the drivers side hook up to. The only vacuum diagrams I have been able to find only show engines with the egr. If anyone has this same engine or just knows where to put the vacuum line I would really appreciate it, trying to figure this out is driving me crazy. Oh yeah don't know if this matters but the carb is a motorcraft 4350 and the only vacuum line going into it is from the ported vacuum switch. Thanks for the help.
Old Apr 1, 2006 | 09:14 PM
Jay87460's Avatar
Jay87460
Brake Booster, PCV, Cruise Control, Heater Controls(if you have A/C)
Jason
Old Apr 2, 2006 | 03:09 PM
dtkkc's Avatar
dtkkc
Ok. i do have A/C but I do not see anywhere to hook a vacuum line up to my heater core. Where exactley would it go? Thanks
Old Apr 2, 2006 | 08:24 PM
Jay87460's Avatar
Jay87460
You should have a vacuum canister in between the battery and the heater core. The purpose of the canister is to supplie vacuum to the a/c system while you are at WOT.
Jason
Old Apr 3, 2006 | 07:53 AM
dtkkc's Avatar
dtkkc
Thanks. I found the canister, it does have a vacuum line coming from it that goes into my firewall and I guess inside the cab. I have looked all over this engine and cannot even find another vacuum port for it to go into. My only thought is that it might go into my carb, I have two ports capped off, one on the top front left and another on the rear right. Oh well, the truck runs fine, might just be an extra useless line. I just don't like not knowing what everything is suppose to do.
Old Aug 28, 2016 | 09:07 PM
Ultimate Automotive Leak Detector's Avatar
Former Vendor
Vacuume Line
My best guess would be the brake booster but with out the vacuum diagram don’t know for sure. But like I said if I was there I would put my tester in the line at the manifold driver side and sure there would more then likely be a plume of smoke coming out of the brake booster. And that would tell you what I find out daily by using this tester for leaks and tracing vacuum lines and that’s just a few of the things this tool can do for you. And that thing the lines are connected to is a vacuum tee.
Old Sep 23, 2016 | 04:49 PM
Former Vendor
Vacuum Line Leaks
Want to know a way to locate a leak in seconds and it works every were every time oil antifreeze gear oil gas transmission vacuum line leaks you name it real easy to locate. And fast. Just click on the name Ultimate above and on profile page click on pitcher to right of page for full description and plenty working pitchers. Click on Ultimate Auto above it will take you to profile page on right side of page click on the pitcher and it will give good description of the tool.
brooklyn
26
Nov 9, 2023 11:21 AM
HoustonDave
13
Jan 9, 2018 06:30 PM
BigSexy78
Feb 4, 2017 06:06 AM
Nathan J. Hickson
Jan 24, 2017 11:19 AM
grandpas1974
Apr 8, 2016 11:34 AM
