C6 shift modulator vacuum source?
Old Dec 6, 2015 | 06:35 PM
mos68x's Avatar
mos68x
I haven't found any sources in Google so I was hoping someone here might know. Anyone know which port to use for the shift modulator on the Holley carbs? I have one that is full vac, but I'm not sure if that is the right one to use and the others are used or labeled for something else.
Thanks
Old Dec 6, 2015 | 06:54 PM
mos68x's Avatar
mos68x
I finally found someone on 460ford that had a similar problem and it looks like they said that you can hook it up to a manifold vac source, which should mean full vac on the carb. Anyone have any info to confirm or dispute this? TIA
Old Dec 6, 2015 | 08:19 PM
68Mercury250Ranger's Avatar
68Mercury250Ranger
are you asking about the modulator valve on the c6 trans or a vacuum valve on the holley carb?
Old Dec 6, 2015 | 08:43 PM
mos68x's Avatar
mos68x
The shift modulator on the C6 trans, I need to find out what kind of vacuum source it needs so that I can hook it up correctly to the Holley, or the manifold if necessary.
Old Dec 6, 2015 | 08:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It requires manifold vacuum.
68Mercury250Ranger
manifold vacuum only, full vacuum no valves. don't hook it up to the carb anywhere.
Old Dec 6, 2015 | 08:47 PM
annaleigh's Avatar
annaleigh
i am pretty sure the C6 transmission modulator vacuum comes directly off the manifold tree...
Old Dec 6, 2015 | 08:51 PM
68Mercury250Ranger
wow everybody is on sunday nite, almost 3 posts stacked onto the same minute. I think we have the answer.
Old Dec 6, 2015 | 10:13 PM
annaleigh's Avatar
annaleigh
here, here
Old Dec 7, 2015 | 07:37 AM
mos68x's Avatar
mos68x
Well the problem is that the Holley's rear fuel bowl partially covers the manifold vacuum port on the Edelbrock, so I'm going to have to use the carb since the OEM vacuum tree is too tall, has too many ports, and I'm too broke to get vacuum plugs or a new port. If it requires full vacuum then there should be no reason that I can't hook it up to the full vacuum port on the Holley which I think is the same size vacuum port as the shift modulator. I'll update when I get it hooked up.
Old Dec 7, 2015 | 08:25 AM
Odisvan's Avatar
Odisvan
Well, that is odd. I have an edelbrock performer intake on 84 with 351 and Holley 600 and there is tons of room behind the carb for the vacuum tee. From that vacuum tree runs my vacuum booster for brakes and line to my C-6 automatic. And another line than runs to some vacuum thing under the brake master cylinder, best I recall. I'd think any port on the Holley is ported vacuum and not full manifold vacuum therefore your vacuum modulator valve on trans will see differing vacuums and perform erratically? Do you have a spacer plate under you Holley that has a vacuum port plug on it that you could use maybe?
Old Dec 7, 2015 | 08:26 AM
Odisvan's Avatar
Odisvan
I believe any carb vacuum port above the bottom carb butterflies is ported.
Old Dec 7, 2015 | 01:39 PM
Billdarr's Avatar
Billdarr
Thanks
From my EFI 1988 5.8l ... I would think "Full" Vacuum from the maifold or a "full"vacuum port from the Carb. Mine gets it's vacuum from the plenum.
Regards, Billdarrp { margin-bottom: 0.1in; line-height: 120%; }
Old Dec 9, 2015 | 09:51 AM
mos68x's Avatar
mos68x
Thanks for the suggestions guys! Hooked up the vac line to the full manifold vacuum port on the Holley and it shifted like normal.
Old Feb 6, 2021 | 11:30 PM
Brandon Frantz's Avatar
Brandon Frantz
I just i stalled a c6 from a 77 on my 95 bronco with a EFI 302 where would i i stall the vacuum line from the modulator
