Fuel Leak
Old Feb 16, 2007 | 02:09 PM
Martin Broll's Avatar
Martin Broll
Fuel Leak
After looking closer I found a leak that ran down the valve cover to the back of the motor!
It's on the fuel filter canister driver side, it looks like the old time oil-sending units. It was very loose so I tightened it , I have remote start so I ran it but it looks like it's leaking from the black plastic part where it connects to the metal
What is the name of this part???
How much?
Old Feb 16, 2007 | 04:36 PM
tjbeggs's Avatar
tjbeggs
what year truck do you have? single wire on the sensor? If its a 97 with a single wire its the fuel filter restriction sender.
Old Feb 16, 2007 | 05:28 PM
Martin Broll
97 f-250 7.3 turbo crew 4x4 swb
Old Feb 16, 2007 | 05:52 PM
remington338's Avatar
remington338
i had a leak like that on my 97 and the oring for the drain was where she was leaking.
also you can check the fed pump that seats wright behind the filter bowl whitch theirs two weap holes under the pump that will leak when pump is bad.
Old Feb 17, 2007 | 07:32 AM
Martin Broll
Is it a dealer item?
Old Feb 17, 2007 | 08:12 AM
Cuda_jim's Avatar
Cuda_jim
It's what Tim said. Dealer item only as far as I know. You might want to check some of the sponsors sites on this page.
Fuel Filter Restricted sensor;
on filter housing 94/95;
on regulator block 96/97
(Ford) E8TZ-9S283-A
(International) 1809435c1
BTW: You may want to bookmark the link in my signature for PSD part numbers. It's not my site so thanks the Wilson's for maintaining this page. The othe links are helpfull too! Save them.
Old Feb 21, 2007 | 08:54 AM
Martin Broll
Thanks Guys, I skipped Ford and went to International to pick up
part#1809435C1 pressure switch and only paid $13.35!!!!
NO MORE LEAK
WildWildWest
6.7L Power Stroke Diesel
24
Sep 3, 2022 03:45 PM
entropyjones
25
Oct 10, 2015 11:18 AM
Tdoyle03
Apr 1, 2015 02:05 PM
artfd
Jan 1, 2012 08:13 PM
DBAPilotDad
Jul 22, 2010 06:45 PM
