Fuel Pressure Switch Leaking Like A Sieve
I finally got all the oil cleaned up from the front of the engine and underside of the truck after fixing the oil leak from the brake vacuum pump seal on the front of the engine a couple months ago and I find diesel fuel dripping on the ground below the engine and a heavy diesel fuel smell when I stop. It left quite a puddle and obviously had started leaking slightly over the last few weeks and finally got worse because it left quite a trail on the underside of the truck from highway driving.
Anyway, looks like the fuel pressure switch gave up the ghost and is peeing diesel fuel when the truck is running. Looks like an easy fix, just need the part and everything is closed today for Canada Day!! Hoping I can get through another 500 miles of driving it this way because I won't have a part or time to fix it until Saturday. No low fuel pressure issues and it isn't spraying fuel everywhere but just a continuous small leak that is making a mess and running down the engine onto the ground.
Doesn't seem to be a problem that people have seen on here that regularly, so just curious if anybody else has run into it.
The following users liked this post:
It's too bad you are having this issue and I have not heard about it from anyone else either. Under most circumstances, I wouldn't be too concerned over a small diesel leak starting a fire. Diesel has a pretty high flash point (compared to gasoline) and yours isn't the first truck out there driving around with a diesel leak. Hopefully it is a pretty easy fix being right on top?
Had trouble finding the issue when doing a search online, so it isn't really common. I'm not concerned about a fire from driving it based on the amount of leak (seems to be worse at idle when the truck isn't using any fuel). I won't be towing so temps will be down. I will call the dealership and find out what it is worth this morning when they open. I have the part number already, just need to confirm it's correct. Looks like about $25 in the US for the part, probably about $45 here in Canada. I will update.
on
Agreed that Diesel is not as volatile as gasoline when it comes to catching fire. However the location of your leak being on top of everything may well increase the risk.. Whatever you decide to do is no skin off my nose..
All that said, you may want to check the former Tousley Ford website here in MN as they have some of the best Ford parts prices on the web:
AutoNation Ford White Bear Lake | Parts & Accessories
Part number BC3Z-9S599-C (Fuel Pressure Switch)
Cdn cost $54 plus tax.
Cheapest I found it in the USA was $22, with retail for about $32. Gotta love how we get screwed on parts up here!!
I started an engine fire once, adding oil to a running engine and spilling a bit on the exhuast manifold.
It burned out before any damage happened, but if you have a leak where more fuel is being added, thats a little different.
I'm always amazed how clean everyones engine looks, mine is dusty and grimey, and I come on here and you guys obviously take much better care of your trucks in the appearance department lol.
http://en.wikipedia.org/wiki/Flash_point
I'm not smart enough to know the numbers.
But yeah, gasoline has a very low temp flash point, you can light it with a lighter at very low temperatures, while diesel has to be heated to be able to light.
In other words, gasoline is vaporizing lots at lower temps, while diesel does not. However, if both are heated equally, the diesel burns first.
Depending what the fuel touches it COULD ignite.Prolly wont happen but the risk is def there.I know if it was my 60k truck I wouldnt drive it,not worth the risk but fire is job security for me.Been to a few diesel fuel fires.Good luck with the fix.
